Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 04-15-2009, 10:37 AM
fokusco is on a distinguished road
Waterjetting ACRYLIC! ummm.. HELP ME!
Ok ladies and gentleman I seem to have run across a huge problem. We have taken on a very large job of cutting 1/4" acrylic... We are making 4" numbers and letters. When we quoted the job and cut a test piece everything went smoothly and the #s and letters came out fantastic! Then we got the job.....
I am having trouble getting the edges from chipping and having a frosting on some of them... Frosting is not that big of a deal but I would like some tips on how to rid of the chiped and exploded edges!
Any tips would be helpful ex: garnet texture and brand, cutting speeds, nozzle height off of material ect,. ANYTHING that will help me get this done!
Thanks all!
Old 04-15-2009, 01:56 PM
LaserImage is on a distinguished road
I wouldn't even consider waterjet cutting acrylic. A laser is a much better choice and will give you almost flame polished edges.
Do you have a laser? Or access to one?
Gary
Old 04-15-2009, 02:24 PM
hmmm... not the answer I was looking to see.. lol
I do not have a laser but I do have access to one... Don't really feel like sub-contracting an already subbed job! lol
anyone else?!
Old 04-15-2009, 11:24 PM
DSL PWR is on a distinguished road
Are you using cast or extruded acrylic? I don't know what the diff would be on a waterjet, but try which ever one you aren't using.
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
Old 04-15-2009, 11:43 PM
jstiltner's Avatar
jstiltner is on a distinguished road
Is it possible that the test piece you cut was actually polycarbonate? AKA lexan? As this would cut much better than acrylic. Sadly I dont have any tips other than thinking that may have been the cause for the difference here. Good luck.
Old 04-16-2009, 09:17 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
I know that when I turn or mill cast acrylic it's fine, but extruded is a nightmare. Worth trying as previously mentioned.
I love deadlines- I like the whooshing sound they make as they fly by.
Old 04-25-2009, 05:22 AM
Signmaker is on a distinguished road
What grade of Garnet are you using? What size nozzle are you using? What size lead in are you using? How are you setting up your sheets?
Cast and extruded acrylics can both be jetted with ease so it doesn't really matter what type of acrylic you use.
Old 04-25-2009, 06:04 PM
307startup is on a distinguished road
What is your pierce height? What is your cut height? What are your feeds & speeds being used?
Old 04-25-2009, 06:20 PM
One of Many is on a distinguished road
Sometimes it helps to double back tape brittle materials onto a backer board for support like 3/32 HDF.
Chipping may be an indicator that the nozzle is advancing too fast on top of the uncut lower depths.
Have you played with the feed rate to prove any theories?
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 06-21-2011, 03:59 PM
mtmcnc is on a distinguished road
try to pierce in low pression about 7000 psi and cutting at 30000 psi . hope it work
  #11   Ban this user!
Old 06-21-2011, 05:52 PM
Fildain is on a distinguished road
So I have been working on our Omax waterjet, and have been working on cutting different thicknesses of acrylic. Not to sure what your machine is but, here is a couple things i learned.
First, put the acrylic on some type of spoilboard, I end up using some scrap luan or something, because where the waterjet splashes back when it hits the slats can cause chipping and damage to the bottom of the piece.
Also i have found that the best way to cut is to pre-drill the pierce points and then line up the jet. This way you dont have the piercing chipping, also i have found that sometimes stress fractures can develop where the waterjet pauses for a second to switch from low to high pressure. To drill the holes I usually print out a to scale pattern that I tape to the top of the work and so i have the pierce points and i can mark a starting location to line up. Oh ya also if you start off the edge of the piece and cut a contour into it, you get rid of the piercing problems.
Again i am not too sure what machine you have, but I know if you are going to be doing alot of this and have an Omax, they have a couple accessories to make this easier. Such as a pull-to-open valve, which opens more controlled then just on/off, so it pierces brittle material better. They also sell a drill head that can attach to the machine, so it drills a pierce point and then starts to cut.
I know we use 80 grit Barton garnet, I am not too sure about the feed speeds because the Omax software works it out on the quality setting.
But I have gotten some good results doing this.
  #12   Ban this user!
Old 06-21-2011, 05:59 PM
So I just pulled up the software to find the feed speeds of .25" cast acrylic.
This is at high pressure (46 ksi)
So it seems that Quality 5 on the Omax, which is the highest is about 20 in/min.
Quality 3, medium, is about 35in/min.
But all this will change with your pressure, and how much garnet per min is released. But hopefully this will give you a ballpark
[IMG] code is Off
Waterjetting Thick Steel Miguel Gonzalez CNC Plasma and Waterjet Machines 5 11-14-2008 05:50 PM
Waterjetting Rubber Miguel Gonzalez CNC Plasma and Waterjet Machines 3 06-18-2008 09:27 PM
Acrylic blfuller123 DIY-CNC Router Table Machines 3 12-28-2006 08:15 AM
Acrylic Mike7 Vacuum forming, Thermoforming Etc 2 10-30-2006 10:16 AM
Melting acrylic Townhill Glass, Plastic and Stone 7 09-05-2006 03:16 PM
