Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 04-14-2009, 10:12 AM
adanowski is on a distinguished road
Exclamation intermac pro A axis ajustment
hello;
i'm using itermac pro ct 5 axis cnc router . and when i start machine and zero out all axis's and all numbers say zero a axis is about 2.30 degrees on minus side.now question is how do i get in and set the machine so i can compensate for the difference.
[IMG] code is Off
New Machine Build- post for 2 axis ez trak versus 3 axis ez vision tooolman G-Code Programing 0 11-28-2008 03:33 PM
Compare Catia and MCX2 for multi axis lathe/4 axis mill bob1112 General CAM Discussion 0 10-10-2008 07:15 PM
One axis (z-axis?) computer controlled testing device TsThorsell Stepper Motors and Drives 3 02-07-2008 12:38 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
Current Ajustment rikkimantha Hobbycnc (Products) 5 09-30-2006 12:46 PM
