Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 02-12-2009, 12:14 AM
graver1 is on a distinguished road
Liquid sand blast stencul mask
I would like to find a material that can be brushed or sprayed, to use on glass, ceramic, metals or stone. I would use a lowpower laser to burn the graphics and the stencil would resist the sand blasting until I removed it with heat or solvent. This is for uneven surfaces. So far Nail polish shows some promise, but does not burn away completly. Same w/ wax, liquid tape, spray enamel, rubber cement.
There is a coating that will leave a mark from the laser, but I want it deeper and I dont have a hi power laser. Any Ideas? LL.
Old 02-12-2009, 12:09 PM
LaserImage is on a distinguished road
Try plasti-dip. I tried it a couple of years ago and it worked pretty well. You will need to put it on pretty thick, but it comes off pretty easily.
Gary
[IMG] code is Off
Mask On Arc Problem Mastercam User Mastercam 12 05-21-2008 08:32 PM
Liquid joinery ThomD DIY-CNC Router Table Machines 4 02-17-2007 02:16 PM
Convert your router to cut vinyl and sand blast as well. ynneb Printing, Scanners, Vinyl cutting and Plotters 17 01-11-2007 09:09 PM
Dust Mask or No Dust Mask Hogpaw CNC Plasma and Waterjet Machines 0 09-08-2006 05:57 AM
DUCKBILL mask contest - was this ever announced? bren CNCzone Club House 0 04-13-2006 07:22 AM
