Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 02-06-2009, 04:32 AM
supremeindex is on a distinguished road
Anyone know how to polish the acrylic or any machine can do that
HI all, i am Lim from Malaysia, currently i getting a project from my customer, and i am using CNC router to slit it into 2" x 52" part, and i need to do a polishing on 1 side. And the minimum requirement is "after polishing, it can not have any line or scratch on the site surface" i try to use diamond edge polishing machine, but got a line on the surface, any one know which type machine can do it ?
Old 02-06-2009, 05:44 AM
dblox is on a distinguished road
Heat
I'm not very experienced in such things, but have you tried using a heatgun or a flame? When I mill clear acrylic I use a butane gas torch on the edge to return the milled surface to an almost glass like finish. Be careful not to set the acrylic alight though...
Old 02-06-2009, 09:52 AM
diecutter is on a distinguished road
I visited a company where all they did all day was fabricate parts from acrylic sheet. They used one of those jeweler's torches (with a hydrogen generator in it as the fuel source) to polish the cut edges.
They cut the sheet with a fine toothed carbide table saw for straight cuts or a cnc for nonlinear shapes and flame polished the edges. The results looked optically clear.
Old 02-06-2009, 10:57 AM
SCRAPWOTSCRAP is on a distinguished road
Hope this helps a little
http://www.cityplastics.com.au/polishing.html
[IMG] code is Off
Need Help!- How to machine acrylic? dneisler General Metalwork Discussion 5 08-20-2008 10:01 AM
How does electro-polish work? BLAMM!! General Metalwork Discussion 2 03-05-2007 10:11 PM
Need help finding or designing for acrylic machine lightorber Glass, Plastic and Stone 4 02-12-2007 01:42 PM
face polish black absolute? nonnsgranite Glass, Plastic and Stone 5 09-15-2006 06:27 PM
How do i polish aluminum? touser General Metalwork Discussion 16 02-01-2006 07:50 AM
