| Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here. |
Hope this is the right place. I have a cnc machine with an adjustable bosch router. I need to cut a couple of 1 1/2 inch holes in two 1/4inch thick bathroom tiles to take a shower mixer. Unfortunately I only have two tiles left of the right colour so can't afford a mistake. I have done some experimenting on similar, different coloured, tiles with various types of cutter. The glass drills seem to cut the surface but any metal cutters glow red at the slightest provocation. Is there anything I can put in to grind through this material? Time is no problem as I can set it to cut in the smallest steps and leave it, although any lubrication would have to be by hand. TIA Dave |
| This is normally done with a coring drill/diamond hole saw? I suppose if you could get past the glazing with a tile spade drill in the center, you might be able to use a carbide coarse rotary file to spiral out from the center. Risky? Rent a coring drill? If routing is your only option, get some other color tiles for practice. Maybe even route out a nest to hold the tiles in the orientation they will be on the wall when cutting the holes to get them located on center. DC
__________________ Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade. |
Stick the tile in a bath of WD40 and peck drill it from the front with a diamond sintered coring drill (like a 1 inch length of copper pipe with lots of little diamonds sintered onto the end). Take your time and you should get through an eigth of an inch thick tile in 10 mins. You will get chipping on the break through (the rear surface). To avoid this wax the tile to be drilled onto another waste (spoil board) tile. Make sure your coring drill has a small hole in its side to let the air out as you push into the tile. Watch out if you're holding the tile by hand under the oil, if it spins it can give you a nasty cut (from experience coring glass plate). [Edit]They've moved on a bit since I last used this type of drill! (showing my age now lol). Google "Diamond Core Bit/ Drill" for more info.[/Edit]
__________________ I love deadlines- I like the whooshing sound they make as they fly by. |
| Dear dhookings, Diamond core bits do not come cheap in the UK from regular tool shops. However, cheap and nasty imports are available on e-bay, and if you only have to make a very few cuts, they should do the job. If you buy on ebay, remember to add the additional expense of mandrels etc. for your drill. An alternative is to buy a blade for your hand hacksaw that is simply a piece of wire with carbide (diamond???) teeth in it. The blade cuts in all directions. The resulting hole may be a bit wonky, but when covered with grout or whatever, you will never give it another thought. Try Screwfix,Axminster or Toolstation. BTW, Toolstation do not charge for delivery on any orders over £10. How on Earth do they do that????? Best wishes, Martin |
| Check these out, have had good luck with them and they are very inexpensive. http://tinyurl.com/djprpn Jeff... |
Lummy, lorks, that is cheap. Can you give us a view on their quality? It all looks a bit too good to be true. Thanks, Best wishes, Martin |
Thanks. I did my bathroom fifteen years ago, and I have no wish to go back in there with any tools, even if it does look a bit "retro". Hey, the bath isn't avocado colour... I'm cool... Best wishes, Martin |
#11
As I only have three tiles of this type left I have decided to make the holes go to the edge of the tile and bought a tile cutter to notch from the edge. I have loads of a different colour so I will experiment with them using the suggestions here. Dave |
#12
| Hold up!
Stick the hole in the centre of the tile mate.
| Ceramic square? | Panther101 | Product Announcements & Manufacturer News | 0 | 08-05-2008 03:26 PM |
| Laser to cut mosaic tiles | ozni | Laser Engraving & Cutting Machines | 1 | 11-05-2007 04:13 PM |
| Ceramic capacitors | aggie_67 | General Electronics Discussion | 1 | 05-27-2006 09:45 PM |
| Ceramic molds | PolyPill | Moldmaking | 2 | 02-04-2006 02:09 AM |
| Ceramic Inserts | Turbine | CNCzone Club House | 2 | 09-24-2003 09:23 PM |
