Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 01-27-2009, 09:57 AM
bdphillips03 is on a distinguished road
Optimal Carbide Insert for Cast Acrylic
I'm using a slant bed CNC chucker lathe with a tool turret to turn cast acrylic rod. I am currently getting an OK finish (running dry) using a DCGT32.52 insert designed for aluminum. Would I benefit buying a DCGT32.51 insert? Both of these are Stellram positive geometry style 64 inserts.
OR am I just plain out using the wrong style insert?
I've also tried HSS inserts as well. I'm trying to acheive a finish that I can flame polish without having to wet sand the part before flaming. Not looking for optical quality like lenses but need a nice clear final finish.
I can post pictures of the parts when I get home.
I also have tool holders that can use VC_1303 inserts and one that uses CC_32.5 inserts along with the DC_32.5 above.
thanks,
Brian
[IMG] code is Off
Need Help!- 1/2"x1/2"x3/16" TiN Carbide insert gbowne1 Metal Working Tooling 8 12-17-2008 11:56 PM
Problem- Cutting steel on lathe with carbide insert. Not smooth. alexccmeister General Metalwork Discussion 18 12-04-2008 08:13 PM
Newbie- Fanuc 6M Optimal Parameters Saluce Fanuc 0 09-11-2008 02:19 PM
Carbide insert designations mikehg1 General Metal Working Machines 5 06-29-2008 10:08 AM
Cutting 2" cast acrylic routski General Material Machining Solutions 4 01-11-2008 02:44 AM
