Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 01-13-2009, 06:20 PM
MechanoMan is on a distinguished road
Cutting polarizing filter glass
I have a small "bullet camera" that may benefit from a polarizing filter.
No one makes filters this small. I can get a larger glass filter fairly cheap. I have Taig and those cheap diamond-grit shaper bits you find at Harbor Freight Tools. I'll worry about the mounting later, I just want the glass cut.
I could probably double-sided tape stick this down, put a layer of packing tape on top, and make a spiral pattern with very, very small Z-drops, with some lubricant/coolant mist.
Is this plausible? These shapers aren't designed for plunging, but do have grit on the tops/tips. Would this type of glass survive? Is there a better tool to try?
Old 02-05-2009, 10:51 AM
ssoptical is on a distinguished road
Talking cutting filter glass
new to this forum,
you could try a diamond coredrill or find an optical shop like the one that i work at. i have been working with glass for 30 years and have been cutting ,
edging, cnc grinding strange shapes.:
[IMG] code is Off
Newbie- Cutting Art Glass jayglass Glass, Plastic and Stone 7 09-12-2008 04:50 PM
Cutting Glass Mcyoda CNC Plasma and Waterjet Machines 2 08-27-2008 06:43 PM
Need Help Cutting Glass!!! ariel 1 Glass, Plastic and Stone 19 07-10-2007 01:53 AM
Cutting glass SRT Mike General Metalwork Discussion 1 05-15-2007 11:13 PM
Glass cutting gabi68 DIY-CNC Router Table Machines 7 11-11-2006 08:34 PM
