Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 01-13-2009, 02:25 PM
Gene-Yo is on a distinguished road
Precison Plastic Rod Materials
Does anyone know where I can find the a plastic solid rod with the following characteristics:
1. High tolerance for the rod outside diameter. I need rod sizes such as 1.00 inch and 1.25 inch material O.D. It needs to be very close to their given measurement such as 1.002" (so within a few thousanths).
2. Self lubricating so a slick plastic like teflon or UHMW.
3. Have good abrasion characteristics such as UHMW, Delrin or Teflon materials.
In fact it could be UHMW, Delrin or Teflon just I cannot find anywhere where they sell this materials in rods with high O.D. tolerances. Usually their tolerances are up to +0.02 inches and some are probably closer to +0.05 inches. And I need closer to +0.002 inches.
Does anyone know where to get this level of precision plastic rod material?
Thanks for the help!
Old 01-13-2009, 04:07 PM
Have you taken some calipers down to your Delrin rod supplier and checked the sizes on their stock. We get Delrin in all sizes from 1/4" up to 2", I just checked a few sizes and they were all within +0.005" and some were better than +0.002". You should be able to find Delrin rod that is suitable and if you cannot I think you are going to have to loosen up your specs because that is the most precisely sized plastic rod I have ever encountered.
[IMG] code is Off
Where to buy materials? Chevy-SS General Metal Working Machines 13 01-26-2009 06:36 PM
Precison Matthews lathes.... ready2go Mini Lathe 0 03-29-2007 12:59 PM
materials ironDigit General Material Machining Solutions 7 06-24-2006 08:43 AM
Materials ryanduc General Metal Working Machines 1 10-09-2004 01:12 PM
materials broncosis DIY-CNC Router Table Machines 27 06-12-2004 07:23 PM
