Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 10-13-2008, 12:34 AM
burik is on a distinguished road
EGAR 320 trouble
HI EVERYBODY!!!
I have 3 mashine tools -EGAR320,Egar 320Ò and glass table with NUM 1040(also Z.Bavellony)
PROBLEMM
after reprogramming EGAR320 I have a mistake at a capture of the tool a spindle approximately in 1-2 degrees.The Tool is incorrectly established in a spindle.
HOW to solve this trouble (with software îr Hardware)?
For reprograming i am use NUMTOOLS WORKSHOP and files beckap my EGAR 320 from Bavellony
Best regards from Russia
Sochi
PUTEVI
Burula Oleg(lead.eng)
gsm@sochi.net
Old 10-14-2008, 10:36 AM
yz426four is on a distinguished road
Talking
WHAT???????????????????????????
Old 10-14-2008, 11:49 PM
Thi spindel with air capture should take definitely the tool from a tooling.Each tool has a dredging.Spindel has ledges.Dredging do not get in ledges---difference of 2.5 degrees.
EXcuse me for my ridiculos English... But can you me will understand
Old 10-17-2008, 07:10 AM
machineoperator is on a distinguished road
Do you mean when your machine goes to pick up a tool from the tool rack that the spindle keys don't line up correctly?
If this is the case it sounds like you need to adjust your spindle locking pin or whatever locks you spindle when it makes a tool change.
Old 12-13-2008, 05:24 AM
bavtec is on a distinguished road
spindle indexage regulation
hI
to do this work you will need a special modul (hardware) for spindle yaskawa inverter that you connect at your inverter and change a value inside only bavelloni technician have this modul. but you can olso buy it by yourself to your local yaskawa distributor....it is not cheaper!!!!
after you find this module i can help you for the procedure.........
best regards
bav tec
Old 12-15-2008, 04:42 AM
Originally Posted by bavtec View Post
hI
best regards
bav tec
THANK YOU!
BUT I dont want buy the Display digital operator (JVOP-132).....
I am solve this problem.
(install interface board from older inverter...and all OK!)
Best regards !
[IMG] code is Off
z bavelloni egar 320 tsjim Glass, Plastic and Stone 23 09-26-2011 08:44 AM
The trouble with SE split63 SolidEdge 5 10-23-2008 11:59 PM
More PIC trouble robe_uk PicStep Controllers 5 10-10-2006 03:13 PM
Arc trouble Graeme TurboCNC 9 06-24-2005 03:31 AM
having trouble getting this to cut right MIKENLN BobCad-Cam 2 04-19-2005 02:24 AM
