Results 1 to 3 of 3
Thread: Optically Clear Plastic Material Recommendation
    Jul 2008
    Question Optically Clear Plastic Material Recommendation
    I am looking for a material recommendation. The requirements are for the following:
    * Optically Clear Rod, 0.25" diameter
    * Machinable
    * Commercially Available & ideally (as always) cheap!
    I have experimented with Extruded Acrylic, however it melts more than it machines. I am reading (here and elsewhere) that Cast Acrylic Machines better than Extruded Acrylic. Are there other materials I can consider? Optical clarity is a must. Thanks in advance.
    Lee
    Onyx Ind.
    Jul 2005
    Yes, extruded acrylic is not machinable, cast machines very nicely.
    I think acrylic is what you need it is even clearer than glass I think.
    Imancarrot might come along sometime and give an opinion; he is the optics Guru^2.
    Registered ImanCarrot's Avatar
    Nov 2005
    UK
    Wouldn't say "expert", but thanks for the compliment
    Cast Acrylic, optical grade is what you want. I CNC lenses all day and as Geof says it machines very nicely indeed.
    Extruded Acrylic does not machine at all well and has many inclusions in the bulk material.
    Polycarb doesn't give a good finish.
    Zeonex machines well, but you got to use a non- hydrcarbon coolant otherwise it reacts with the material.
    CR39 is quite a common polymer that's used to make lenses.
    My favourite, however, is MR7- it's got quite a high refractive index for a plastic and machines crystal clear, it's not cheap though and I can only get it from Japan.
    Cast Acrylic would be your best all round bet. I'm not sure if you would get an optical finish using conventional machining which Geof knows far more about than me: I use Diamond Machining (Google Diamond Machining Wiki) and make lenses for some of the strictest applications. You might get a nice polished surface using conventional machinin and flame polishing, Cerox polishing or any proprietary plastic polishing, but it will be not be anywhere near "optical" grade. And the surface profile would never be acceptable for imaging.
    Here's some I made earlier.
    [Edit]
    What's your application? Is it purely a pretty thing, or an actual optical imaging component? What wavelength will you be operating at- Visible, Infrared, Ultraviolet? These factors all affect the choice of material.
    [/Edit]
    Oh, I'd expect to pay around £15.85 for optical grade cast acrylic, 6mm dia, 5 metres length supplied in 1 metre lengths (5X 1 metre lengths for £15.85). It goes up to about £25.45 for 10mm diameter (same quantities).
    The transmission is about 92% (visible), but this can be dramaticaly increased by anti-reflection coating.
    Ask away! I'll do me best to help!
    Attached Thumbnails Attached Thumbnails Optically Clear Plastic Material Recommendation-image02.jpg
    I love deadlines- I like the whooshing sound they make as they fly by.
  1. Plastic Material Suppliers
    By vetteboy86 in forum Engraving Machines
    Last Post: 10-06-2008, 09:15 AM
  2. Plastic material in VMC windows??
    By CNC Viking in forum General Metal Working Machines
    Last Post: 08-28-2008, 05:15 PM
  3. Plastic as the mold material
    By gcn2339 in forum Vacuum forming, Thermoforming Etc
    Last Post: 07-30-2007, 04:31 PM
  4. Optically Clear Adhesive
    By ejlouis in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 07-24-2007, 05:05 PM
  5. Material recommendation for a smooth finish on ACME threads?
    By pkelecy in forum Mechanical Calculations/Engineering Design
    Last Post: 11-01-2006, 10:02 AM
