Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 10-11-2004, 04:10 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Arrow Images Milled on Plastic/Acrylic Sheet
Help!
I have been messing around a bit and misplaced my notes on how to:
Determine step-over for x and y axis when making a photo-engrave on plastic. (in raster format)
Seems like it was 5-10 percent of the bit (endmill) diameter - or have I got that all wrong?
There must also be a relationship of image size to tool/bit size too.
Any good ideas?
I'd like to try make something about 25mm diameter (ok--an inch) and have reasonable detail-- but not necessarily "currency/coinage" quality. Depth of cut doesn't have to be too much, a few mm up to 1/8 inch or less. Kinda like a small mold for making toy coins or such.
I went looking for the well imaged "timber wolf and the "eagle" and had no luck - thought maybe I'd find info there - but no joy so I cry, " Help- Please" Thanks - Jim
PS- if you have a good example, showing all the above - I'd love to see it.
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 10-12-2004, 08:30 AM
kong is on a distinguished road
Whiteriver made those engravings, they are in his photo gallery. They also feature in a thread in the liberty routers section, but I don't know which thread although I know it is looong!
There we go, I am now subscribed so I can steal the info too
Old 10-12-2004, 10:18 AM
High Seas's Avatar
Gold Member
Kong
Man - 42 pages of threads at 25 threads per page - and little luck so far
BUT, I haven't given up yet. May just run some experiments - relating pixel size to bit and step over. I've got AcmeProfiler and a few others that CAN do the work.
But, what I'm looking for is:
1. a quick import of an image into MACH2, (this is pretty straight forward)
2. set the x/y step based on image size, set the depth of pass, (here it gets confusing)
3. then select the tool so I don't wipe out the image!
TIA - Jim
Back to the grind.
Old 10-12-2004, 10:42 AM
Unbelievable, I just went to cnczone homepage, and one of whiterivers works of art was staring at me! Anyhow, here is the link to his user gallery - http://www.cnczone.com/gallery/showg...00&ppuser=1498
And now off to find the thread........
Here you go!
Router pics
Phew
Old 10-12-2004, 11:35 AM
High Seas's Avatar
Gold Member
Kong -- Thanks for That!!!
I've found the MACH2 data on the yahoo as well - took a while - but Art has some great tips - will cook it all down and post my results in a bit!
Jim
Old 06-08-2005, 06:12 PM
Mac T. Knife is on a distinguished road
Smile
Jim
Is it done yet??
Old 06-10-2005, 12:44 PM
Gold Member
mcmmach is on a distinguished road
According to a old cnc engraving program I have each pin on an IBM Graphics dot matrix printer is 1/72" diameter (.01389).
I have had good results using a 1/32" ball end mill cutting up to .035 deep using a .020 stepover to engrave images in pine and MDF.
A 8" x 10" (close to normal picture size) can take up to 6 hours to cut.
Thanks, Dean
[IMG] code is Off
Having trouble cutting aluminum sheet fastturbovet General Metalwork Discussion 40 06-14-2005 11:33 PM
Help machining copper sheet fastturbovet General Metalwork Discussion 2 03-26-2005 01:47 AM
Linking Sheet Metal Props. wocowski Solidworks 0 02-18-2005 03:03 PM
How to change the setup sheet format? cwww General CAM Discussion 2 06-30-2004 03:28 PM
How do I post multiple images in my thread? Rekd CNCzone.com FAQ 0 04-03-2004 06:10 PM
