Results 1 to 3 of 3
Thread: CNC plastic cutting help!
    Aug 2008
    Hi guys i am new to this site and to the world of CNC, for the last few weeks i have been researching on CNC mills and believe i have a fairly good idea and general background of CNC machines.
    Getting to the point I am a case modder, I like to cut designs and do fancy cuts in my work, I make custom cases and engrave/cut symbols on my cases. Up till now I have been using a dremel which gives me a tacky job, so I want to move to something more professional such as a CNC machine.
    The main material I am cutting is PVC Foam core, or Sintra, basically its a styrofam like plastic and is easy to route. I might also use engraving plastic for designs and stuff on top. I will also use this CNC to cut acrylic sheets (plexi glass).
    My budget for this is about $1400, but I would love to save money...I dont really want to make it my self either, I perfer to get the machine nicely, professionaly done.
    I saw Sherline has some good CNC mills I could purchase and are all in my price range, such as this:
    http://www.sherlinedirect.com/index....Product_ID=745
    I am assuming that a 3 axis mill is what I need, and perhaps the 12" base version. I also would like to find a package that has everything I need, including the stepper motors, etc...
    Can anyone help me find a CNC machine that fits my needs here and price range (1400 USD)?
    This is the place i have been looking for:
    http://www.sherlinedirect.com/index....&category_ID=3
    or another place I can get them for a good price?
    Aug 2008
    no1? comeon
    Aug 2008
    For what you're doing I would recommend this machine.
    http://www.romaxxcnc.com/
    I considered it, but ultimately passed because I want to be able to cut aluminum as well as plastics. It should work perfectly for small case mod jobs.
    For cutting plastics I found these "router" bits.
    http://www.micro100.com/inch/sfp.html
    I posted asking for detailed information on cutting PVC but no one answered. The above bits will cut plastic and eject the chips due to the extreme angle of the flute. I am still waiting for my machine so I don't know the optimum RPM and feedrates yet. :P Good luck, Jim
  1. Video of Bridgeport CNC series I cutting plastic
    By metal_bender2 in forum Bridgeport and Hardinge Mills
    Last Post: 05-16-2008, 07:50 AM
  2. Cutting rectangles in Plastic too big for my Mill
    By djh82uk in forum General Material Machining Solutions
    Last Post: 12-23-2007, 11:10 AM
  3. RFQ - Cutting Thin Plastic Sheet
    By ukchris in forum Employment Opportunity
    Last Post: 12-06-2006, 09:16 PM
  4. problems cutting plastic
    By ChristopherWood in forum WoodWorking
    Last Post: 05-10-2006, 05:53 AM
  5. PEEK plastic cutting Q's
    By Petro Chem in forum General Metal Working Machines
    Last Post: 09-18-2003, 05:11 PM
