Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 08-21-2008, 11:02 AM
vividdezigns is on a distinguished road
Plasstic routing
I do not know were to post this at. I am looking for a new way to route plastic trash dumpster lids rather than using a end mill or router bit. I ahve 2 practical cnc tables and use win cnc with autocad, solidowrks and bobcam right now. are there any hot knifes or something liek that i can cut the material with. I basically make a square cut and then make a forward then half circle then forward to cut a hinge.
Can n e one help.
Old 08-21-2008, 11:26 AM
cut more is on a distinguished road
Cutting plastic
vividdezigns,
I have a practicalcnc router/plasma table too.
If a hot knife will cut through the plastic, why not just mount one where your router goes? Or just add another Z axis with the hot knife on it.
Hope that helps,
Cutmore
Old 08-21-2008, 12:01 PM
LeeWay's Avatar
LeeWay is on a distinguished road
Would a fine pointed soldering iron cut it? Sure wouldn't have as much mess to clean up this way. No chips.
Lee
Old 08-21-2008, 02:04 PM
plastic
Na, the plastic is 2.85-3.0 mm thick when your doing an inside removel, and the deminsions of the inside removal are, 33x52 in a square. Then the router cuts the hinges they are 1 inch deep but the material thickness is only 2.85-3.00 mm thick, just a top and a bottom. I ahve attached a quick drawing of the solid hinge on bottom and were the cutouot are on the top, there are 2 of these hinges on each part.
Tags
cnc, cut, heat, plastic
[IMG] code is Off
Help Routing MDF? lgroulx200 DIY-CNC Router Table Machines 7 09-17-2008 07:09 PM
New to cnc routing Duster360 Commercial CNC Wood Routers 6 08-15-2008 02:07 PM
Routing metal cxixer General Metalwork Discussion 16 03-12-2008 07:12 AM
New to CNC Routing need some help .... Beardown DIY-CNC Router Table Machines 8 05-05-2007 09:37 AM
Q on CNC PCB Routing soundmotor DIY-CNC Router Table Machines 7 04-27-2006 06:16 AM
