Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 06-24-2008, 04:07 PM
TMaster is on a distinguished road
Name this plastic
I have a Air control valve here, and I need to buy some material to make a bracket for it. It is injection molded for sure. What type of plastic is this so i know what it buy. I plan on using self tapping screws into it.
It is a harder plastic then then the delrin and nylon I have here. Delrin is too soft and elongation.
ID:	62033   Click image for larger version
ID:	62034   Click image for larger version
Old 06-25-2008, 09:29 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
It will be PVC or ABS.
Make your bracket out of aluminum.
I wouldn't be screwing into the solenoid cover if that is what you are thinking. Those holes down the side are for mounting
www.integratedmechanical.ca
Old 06-25-2008, 11:07 AM
I was going to use aluminum and some nice machine screws but the screws that my Boss wants to use for cosmetic reasons break off in aluminum (self tapping phillips). Yes I will be also screwing into the top of the solenoid about 3/16" deep right where those dowel pin indentations are on the top. It should be fine. The old version solenoids were like that. I'll find out lol!!!
I think i will try some ABS, thanks.
Old 06-25-2008, 11:41 AM
DareBee's Avatar
You need bigger pilot holes.
Old 06-25-2008, 11:49 AM
Yeah I thought about that. I was using almost the smallest size indicated. hmm. Its a number #4, 4-20, 4-24 size screw. Hole size should be wire gauge 44 to 41 i think. .0860" to .0960" OD. I tried it with a 2.2mm(.0866) drill bit and the screw broke off on the second hole. Using some 6061. What do you recommend? using the #41?
Old 06-25-2008, 01:52 PM
*Registered*
Mike Stevenson is on a distinguished road
Plactic injection PVC or ABS? I don't think so. Those are vacuum formed plastics.
Old 07-12-2008, 09:34 PM
warrenb is on a distinguished road
Disagree
There are ejector or vent pin marks on the picture and the corners are too tight for that small of a thermoform part.
I'm guessing it's one of the four. Polystyrene, ABS, or Kydex, or Nylon. Or it could be some sort of fancy polymer. Hard to tell without touching it. Nylon is the only one that won't react to a solvent. Kydex is second. ABS and PS are terrible around acetone and the like. Kydex is easy to work with and heat form so if you need to make a bracket that might be your best bet. they also make the textured sheets (see a 'plastic' gun holster, that's kydex.)
good luck
Old 07-12-2008, 10:58 PM
Originally Posted by warrenb View Post
...I'm guessing it's one of the four. Polystyrene, ABS, or Kydex, or Nylon......
You missed one; Polycarbonate. Personally I think it is unlikely to be Polystyrene, my guess is glass reinforced ABS, Nylon or Polycarbonate and I would put a six pack of beer on the Polycarbonate.
[IMG] code is Off
plastic question yousif_1985 Glass, Plastic and Stone 1 11-23-2007 12:48 AM
My Plastic CNC alecu7 Open Source CNC Machine Designs 5 11-16-2007 12:44 PM
2 ply engraving plastic? DennisCNC Engraving Machines 2 05-07-2007 06:37 PM
Using plastic? ZipSnipe Diemaking and Diecutting 4 01-29-2007 09:21 AM
Plastic cost joecnc2006 Glass, Plastic and Stone 2 12-03-2005 09:45 PM
