Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 05-20-2008, 11:04 AM
acondit's Avatar
acondit is on a distinguished road
Dealing with an oops in HDPE
Is it possible to repair an oops in HDPE (fill a hole)? I had two mirror parts and when I created the gcode to machine them, I failed to correctly mirror four holes. Is it feasible to fill the extra holes in order to salvage the parts? Or, do I just need to machine new parts.
If it is possible to fill the holes what would you use (turned HDPE rod, epoxy, ???)?
Thanks in advance,
Alan
http://www.alansmachineworks.com
Old 05-22-2008, 03:31 PM
SCRAPWOTSCRAP is on a distinguished road
Not advisable. Replace your divots in golf.....not HDPE!
Old 05-22-2008, 06:11 PM
acondit's Avatar
I was afraid that was probably the answer.
I drilled the extra holes on the mill and the parts work fine. They just don't look good.
Alan
Old 05-23-2008, 01:16 PM
spascoe is on a distinguished road
If there is a HDPE tank fabricator in your area they may be able to help by melting a small amount of HDPE welding rod into the hole for you. You would have to clean it up after the fact, but it would create a real bond. Not one you could machine a second time though.
[IMG] code is Off
Oops, and Oops Again. Geof Safety Zone 11 02-28-2008 05:31 PM
Dealing with metal plate that is larger than table size pmurdock General Metalwork Discussion 8 02-10-2008 08:04 AM
Dealing with backlash cyclestart LinuxCNC (formerly EMC2) 2 05-05-2007 01:15 AM
What happened to my post? Oops, I broke the rules, Sorry! low_48 BobCad-Cam 1 07-18-2005 07:43 PM
