Results 1 to 2 of 2
Thread: Drilling through Borax Crystals - advice needed
    Apr 2007
    Hi. Last week, I was driving through the Mohave Desert of CA, and happened to pass through the town of Boron. Being a Chem Eng by training, I just had to stop at the "Borax Museum".
    I ended up buying a small bag of Borax Crystals about 1/2 in on each side - sort of shaped like prisms. It turns out that you can polish / sand them up a bit, and they make sort of a pearl like surface. It will dissolve in hot water, so you can imagine it will not replace diamonds.
    We did manage to polish these up some with 400 grit wet sanding, but 800 would be better. He tried a hack saw to split the stones, but they just turned to powder - but - he was able to sort of cleave them with a chisel.
    In any event, my 10 yr old son would like to drill some holes in a few pieces to make a necklace for my wife for Mother's day, so time to experiment (and stone quantity) is limited. I have access to a small drill press, so that is the tool of choice if it is going to work, and a variety of TiN coated drill bits - mostly for wood / Al use.
    Questions
    - Suggestions for a proper / easy to obtain drill bit - approx 1/8 inch ?
    - Drilling speed - more like wood or more like steel ?
    Oct 2006
    U.S.
    A maintenance department friend once drilled a thin piece of plexiglass backwards to keep it from cracking. Not really sure if this would work for you. Good luck.
  1. Drilling advice on CNC Lathe
    By motter71 in forum General Metalwork Discussion
    Last Post: 12-06-2006, 10:02 AM
  2. 20Mhz crystals
    By PsyKotyk in forum PIC Programing / Design
    Last Post: 11-08-2006, 08:51 PM
  3. deep drilling tool needed
    By Buddy Swanson in forum CNC Tooling
    Last Post: 08-21-2006, 06:54 PM
  4. advice needed
    By trubleshtr in forum General Electronics Discussion
    Last Post: 04-21-2005, 09:48 PM
  5. Little advice needed
    By STUG in forum DIY CNC Router Table Machines
    Last Post: 01-25-2005, 08:11 PM
