Results 1 to 4 of 4
Thread: Engraving plexi for Edge-lit designs; Proper bits, settings?
    Jan 2008
    I'm planning to engrave vector-based line drawings into plexi using my school's CNC router for two purposes: 1) to make edge-lit plexi displays, and 2) for printmaking (inking up intaglio style).
    I'm looking for a suitable bit that will engrave as shallow and narrow as possible. The bit that I found in the MSC catalog is a conical carbide router bit:
    http://www1.mscdirect.com/CGI/NNSRIT?PMAKA=05479159
    (image is attached to post)
    This will be my first time using a CNC router and I'm already intimidated by the prospects of bits breaking, plastic melting, etc... so if you have any suggestions or advice about proper bits, router speed, materials (esp for edge-lighting!) please let me know!
    -mike
    Attached Thumbnails Attached Thumbnails Engraving plexi for Edge-lit designs; Proper bits, settings?-0547915-11.jpg
    Registered MICA's Avatar
    Oct 2005
    I too would like to know the answer.
    Also any special cutting fluid to use to help the finish ?
    Mar 2005
    cutting fluid...
    I have used windex with very good results. You must have higher feed rates in order to keep chips from welding themselves back onto the groove, but with small details usually associated with engraving, its not practical and sometimes will cause my machine to loose steps. Windex keeps things lubricated, disepates heat and doesn't bother plexi. I hope you find this helpful.
    Doug
    Feb 2006
    dishwashing detergent liquid is also a good lubricant
    In the words of the Toolman--If you didn't make it yourself, it's not really yours!
    Remember- done beats perfect every time!!
  1. Engraving Bits
    By pike88 in forum Engraving Machines
    Last Post: 03-26-2009, 06:12 AM
  2. Need Help on Grinding Engraving Bits
    By metalikha joel in forum Toolgrinding & Toolgrinding Machines
    Last Post: 12-22-2006, 10:39 PM
  3. Engraving Bits
    By JMFabrications in forum General Metalwork Discussion
    Last Post: 03-15-2006, 08:08 PM
  4. End mills engraving bits
    By signIT in forum General Material Machining Solutions
    Last Post: 09-12-2004, 11:45 PM
  5. Intro + engraving bits
    By Swede in forum General Metal Working Machines
    Last Post: 02-07-2004, 03:47 PM
