Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 01-09-2008, 08:28 PM
Sbthomas13's Avatar
Sbthomas13 is on a distinguished road
Machining High Density Polyethylene (HDPE)
I have to cut 3/4" HDPE and 1/2" HDPE. My machine and tool specifications are as follows:
The Bit:
- CMT Brand
- 1/4" Diameter
- 1/4" Shank
- 1" Cut Depth
- 2-1/2" Length
- 2 Flute
Router:
- Porter and Cable Brand
- Electronic five-speed: 10,000; 13,000; 16,000; 19,000; 21,000 RPM
What feedrate (IPM), spindle speed (RPM), and depth of cut should I make per pass?
Old 01-14-2008, 02:15 PM
mekdad is on a distinguished road
go fast
I have cut a lot of HDPE my mills only have 10000 rpm but if I had more rpm i could go faster I can run 175 ipm with 10000 rpm I would recomend start there and work up more rpm then ipm just keep an eye on the chip if it gets to thick go more rpm you can push it pretty hard its a fun mat. to work with ps keep sharp tools handy
you never know what you can do, until you have to undo something you have done!
Old 01-25-2008, 06:57 AM
mcwilsonmfg is on a distinguished road
machine as fast rpm and ipm as you can until the material starts to melt and then back r down on the rpm. it cuts really nice unles your running it on a lathe, then it winds up on everything because you just cant push it hard enough to break the chip.
[IMG] code is Off
High Density Urethane Foam (A.K.A. Butter-board) rigo430 General Material Machining Solutions 2 09-10-2010 01:06 PM
budget molding... how to mold help w/ High-Density Polyethylene blackpinesnake Moldmaking 8 10-01-2007 03:40 PM
cutting data for Delrin and High Molecular Weight Polyethylene jedioliver Glass, Plastic and Stone 28 11-14-2006 07:23 AM
Where to buy high density foam? WarrenW General Material Machining Solutions 4 11-07-2006 01:06 AM
high-density polyethylene MBG General Metalwork Discussion 7 09-13-2005 07:31 AM
