Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 01-05-2008, 09:20 PM
DANTAMPA is on a distinguished road
looking for a plastic that cold forms,wont shatter
I have a injection moulded part that is shaped like a "U".
The part is 2 inches wide,1 inch across the top,and .100 thick.
it is like a plastic clip.
I had some made out of a 6/6 nylon and it worked great in florida,but when subject to 20 degrees F.,and bent to extremes,it shattered and pieces when flying.
Im concerned about a possible eye injury.I would rather the part cold form that shatter at temps below 32 degrees to - 20 F.
Please if you have any suggestions for a plastic that wont brek,but still reacks like a composite ot nylon from 32 to 125 D F.
The mold is built for .016 shrink,Thank you,Dan
Old 01-05-2008, 10:26 PM
ScottC is on a distinguished road
a grade of polycarbonate might be an option, from memory, PC has both a lower and higher operating service than 66..becareful about colouring pc though, loose a bit of its impact strength when adding a masterbatch etc..
Old 01-06-2008, 08:34 AM
Thanks,
Thanks for the advice,Dan
[IMG] code is Off
A Cold Few Days.... santiniuk Europe Club House 6 06-26-2010 02:49 AM
cold gun fourperf Fadal 4 11-14-2007 12:28 PM
Anyone for a DIY Cold Saw? damae General Metal Working Machines 12 10-14-2007 11:27 AM
How cold is to cold for BP Series I CNC jho5820705 Bridgeport and Hardinge Mills 15 12-20-2006 07:13 PM
gas prices and alternate forms of transportation CNCadmin CNCzone Club House 35 07-21-2006 10:00 PM
