Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 12-06-2007, 02:47 AM
davidsutton is on a distinguished road
plastic blocks for mould making
I need to make a 2 part mould in which to pour molten wax into for casting.
I need blocks of plastic around 150mm x 200mm x 60mm, does anyone know of a UK supplier? or even the name of a product?
The plastic I need to use just needs to be able to be cut cleanly in my cnc machine with a ball nose cutter and be suitable for holding molten wax.
So far I have made test moulds using wood (oak) but I need something that will release the solidified wax more cleanly.
Old 12-06-2007, 05:41 PM
Eurisko is on a distinguished road
Hi David,
I think that Delrin would be a good choice for what you have in mind.
It machines very nicely, and should easily handle molten wax.
Check out Ebay for some great deals on surplus Delrin blocks and rods.
You can probably find it locally from a metals and plastics supplier, but the cost will be prohibitive.
Another option would be a two-part polyurethane casting resin. This can be found at local hobby shops, and of course, Ebay.
[IMG] code is Off
Milling Black plastic blocks joguy Machinist Feedback 6 11-20-2008 12:57 PM
Building blocks for mould/plug construction? Splint Composites, Exotic Metals etc 1 01-23-2008 09:33 AM
Suggest software/machines for making tyre mould Janardhan Moldmaking 3 12-07-2007 06:34 AM
Alu. mould making end mill question? GalaticDan Moldmaking 2 11-30-2006 12:42 AM
WHere to buy Plastic Blocks?? carguy327 Glass, Plastic and Stone 3 08-03-2006 08:30 PM
