Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 11-11-2007, 05:05 PM
Dannyho is on a distinguished road
Question tooling for complicated borosilicate(pyrex) parts
I'm currently doing a final design project towards my mechanical engineering degree and I'm in need of assistance in machining certain parts. Due to a confidentiality agreement I can't explain what the part is for but i can describe my requirements.
I need to mill a groove into 1 to 1 1/2 inch thick piece of 7040 pyrex, or another borosilicate glass, that's the easy part. I also need to put a 1/4" radius along one edge. and a 3/8"x45* chamfer on another edge. I'm not familiar with machining this material and would like references regarding the process.
I am with the understanding that, along with the proper coolant, I need Diamond coated end mills to do this, and I've found those, but I'm unsure where to get a concave radius or chamfer mill that is diamond coated. Is that even necessary? I also dont have much of an idea of what RPM(cutting speed) I should be using.
what companies should I contact regarding that?
Thank you in advance
Dan Hoinsky
[IMG] code is Off
Complicated for me, Simple for you? dms04d Vacuum forming, Thermoforming Etc 2 08-04-2007 08:51 PM
Complicated Maths Problem!...Long Shot... diarmaid Hobby Discussion 17 10-17-2006 03:24 AM
QC 30 Tooling daewooevc Bridgeport and Hardinge Mills 2 01-09-2006 09:36 AM
Save 100% on Tooling cost and set up time on milling thin parts with the Doo-Bee Stop DynaPowernamics Product Announcements & Manufacturer News 5 05-28-2005 09:17 PM
How complicated is it? turmite Rhino 3D 2 09-04-2003 06:23 AM
