| Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here. |
I came across these plexiglas filter housings I used to make and thought I would show what can be done machining acrylic with a bit of care. The OD is 2.600" and the internal chambers are about 1.2"; they look bigger viewed through the curved walls. The hole passing right through the top piece in the first picture is 3/32" going through a distance of 1.78" which is about 19 x dia. The outside was polished in the lathe after machining in two steps; wet sanding with wet&dry emery paper followed by Brasso on a linen cloth. These were done on a small manual lathe using all hand ground HSS tooling with zero top rake. Lubrication and cooling was with a soap solution.
| ShopTask under glass...Plexiglas | HogDog | Shopmaster/Shoptask | 19 | 08-19-2009 04:59 PM |
| 3d machining | MarshCustom | FeatureCAM CAD/CAM | 7 | 11-14-2007 04:49 PM |
| Milling Plexiglas | Kristy | Benchtop Machines | 14 | 10-29-2007 08:59 AM |
| Machining anodized parts or anodize after machining? | SRT Mike | General Metalwork Discussion | 4 | 03-11-2006 11:22 PM |
| One Hit Machining | CRPDGAZ | Hard and High Speed Machining | 10 | 03-24-2004 01:52 AM |
