| Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here. |
I have a customer wanting me to route out some 1/2" thick pieces of plexiglass. I am using a Thermwood CNC router. I am wondering what kind of spindle speeds, feed rates, and cut depths to use. Also would a standard straight cut, carbide tipped, 2 flute router bit do the job? My main concerns are chipping out (which is why I think a straight cut or maybe a down sheapering is best) and then I wonder about melting it which is why I ask about spindle speed and feed rates. Any help is greatly appriciated! |
| Quite low spindle speeds, I think, so you don't melt the material. Try out on some scraps. You will know if spindle is too fast. Plastic will melt into the cutter flutes and clog up things. Make sure test pass not too deep, as you may start pushing a solid non cutting cutter as a plough. Keep PLENTY of air so no swarf gets eaten by the leading edge of the cut. You can push fairly amazing feed rates once you get it right.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
| It's actually the opposite. Very high spindle speeds and feeds. 18,000 rpms and a feed rate of > 100 ipm. Maybe take two depth cuts on 1/2". Orange County Industrial Plastics |
| Get a tool made for plastics, maybe something like these. http://www.vortextool.com/index.cfm?...category_id=52 Depending on the part, cut it in one or two passes, then make a cleanup pass of about .030. Depends on the part, but you should be able to make the rough passes at 150-200ipm. Maybe a little slower on the cleanup pass, depends on finish quality your getting.
9500 RPM Feedrate: 8 mm/s (19 IPM) Depth of cut: 2mm (5/64") For a 1/8" 2 flute router 9500 RPM Feedrate: 20 mm/s (47 IPM) Depth of cut: 1.5mm (around 1/16") The tool is not air-cooled or anything. I have no problem cutting plexiglas with these speeds but it might be a little slow for a commercial purpose...
__________________ EasyPrototype |
| rfq-----custom black plexiglass sheet | tooldzinr | Employment Opportunity | 6 | 05-28-2009 10:16 AM |
| Help Routing MDF? | lgroulx200 | DIY-CNC Router Table Machines | 7 | 09-17-2008 07:09 PM |
| Feedrate and RPM for a Plexiglass mold | gabi68 | Moldmaking | 5 | 04-11-2008 09:49 PM |
| New to CNC Routing need some help .... | Beardown | DIY-CNC Router Table Machines | 8 | 05-05-2007 09:37 AM |
| advice please- holding down extrusion for routing | Joa | DIY-CNC Router Table Machines | 4 | 01-17-2007 09:12 PM |
