Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 10-08-2007, 03:55 AM
davidsutton is on a distinguished road
Unhappy advice on machining wax
Hi there,
Can anyone give me any advice on machining wax on my 3 axis cnc machine?
I bought some casting wax from an art suppliers, roughed it with 6mm deep passes using a 6mm diameter roughing tool - which went fine, but when I came to the finish pass using a 3mm diameter finishing tool the tool 'held the wax on the flutes' and did not come away from the stock cleanly at all.
Is it my choice of cutting tools and milling strategy thats the problem or is it the composition of the wax?
My main aim is lost wax casting so the wax needs to be able to be melted out again....
Old 10-25-2007, 02:02 AM
Stepper Monkey is on a distinguished road
I'm betting it was that low melting temp, rather smelly brown stuff that is most commonly used by artists, especially for bronze casting. If you got that stuff to machine at all with any bit, consider it quite an accomplishment!
You really need harder waxes that are either designed for CNC, or a medium to hard jewelers hand-carving wax. Usually it is purple, blue, or green (denoting hardness), and blue seems to work the best. Green is often chosen at it is the hardest, but it gets more brittle as well for little if any noticeable difference over blue. All of it burns out very cleanly.
Old 10-25-2007, 03:22 AM
donald_ortega is on a distinguished road
Try Freemans Machinable Wax In Ohio..google It I Have Had Some Good Results.
Don
Smile perfectly right
cheers for the advice - I went back to the wax suppliers web site to see what I had bought and it turned out to be casting wax rather than carving wax.
I have now ordered some carving wax so hopefully I can get my machine producing parts very soon - thanks for the advice!!
[IMG] code is Off
Machining knife sharpening stone advice plz ImanCarrot Glass, Plastic and Stone 2 07-25-2007 10:57 AM
New and in need of some advice... well alot of advice! GoonShoes Bridgeport and Hardinge Mills 9 05-30-2007 07:03 AM
Surface machining advice Julian M Mastercam 0 01-26-2007 02:19 PM
New To Machining-ADVICE NEEDED PLEASE phyter23 Benchtop Machines 4 12-09-2006 04:47 PM
Machining anodized parts or anodize after machining? SRT Mike General Metalwork Discussion 4 03-11-2006 11:22 PM
