Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 10-04-2007, 01:32 PM
carguy327 is on a distinguished road
Arrow Clearing out ½" deep 1" wide in Acrylic
Hello everyone,
I usually use a ¼" onsrud bit to cut acrylic sheet..
But at this width and depth I think I may be milling or a while.
I usually cut 0.1" ipr (depth per cut)
I have a 3 flute ½" aluminum cutting bit and wonder if it will work and if it could work what feed and speed am I using?
Gerald
[IMG] code is Off
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 12:15 AM
drilling through 1" acrylic rod over 8"lenth jstwinbaby General Material Machining Solutions 3 12-08-2007 01:12 AM
Groove of deep:0,39" thickness:0,02125" frad8 WoodWorking 3 03-22-2007 12:44 AM
Vertical system "jerks" and "bangs"?? REVCAM_Bob Servo Motors and Drives 5 06-12-2006 09:09 AM
Add "View New Posts" to "Main Menu" Mr.Chips Forum Questions or Problems 4 04-21-2004 10:54 PM
