Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 09-29-2007, 03:38 PM
chakup is on a distinguished road
Best method for cutting down delrin?
So I have some 12x12 acetal plate, whats the best way to cut this into 3" sections?
Old 09-29-2007, 08:39 PM
DennisCNC's Avatar
DennisCNC is on a distinguished road
I would use a wood table saw or skilsaw with a guide clamped to the plastic plate to get straight cuts.
Dennis
Old 09-29-2007, 09:18 PM
Any recommendations on blade type to use?
Old 09-29-2007, 09:28 PM
samhyto is on a distinguished road
Sawing Plastic
As long as it is sharp, it will cut it! We use a carbide toothed blade with great results!
Sam
Old 09-29-2007, 11:40 PM
awesome thanks guys. was worried about # of teeth etc. will have to go pick up a new blade to cut these down while waiting on my HF X3.
Old 09-30-2007, 06:53 PM
Get what is called a Triple Chip blade. It will be labelled for cutting plastic and nonferrous metals.
It is possible to cut Delrin with a sharp wood blade but you get a much smoother cut with less blade vibration using the triple chip blade.
[IMG] code is Off
cutting data for Delrin and High Molecular Weight Polyethylene jedioliver Glass, Plastic and Stone 28 11-14-2006 07:23 AM
What method will be more accurate? DennisCNC Mechanical Calculations/Engineering Design 9 09-01-2006 05:44 PM
Best method to make this Moondog General Metal Working Machines 14 10-07-2004 05:49 AM
Picture opening method. ynneb Suggestions for the CNCzone.com site. 7 08-01-2004 12:29 AM
Best Method musky2much WoodWorking 1 10-13-2003 08:59 AM
