Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 09-12-2007, 05:46 PM
d11rdozer is on a distinguished road
Calculating feed rates and speeds for ABS
Hi all
Have been trying to find the correct surface speed for culculating feed rates for ABS but with no succsess. My router is "slow" max 250mm/min and have tried using both a Dremmel and a Kress router but even at the lowest speed on the bit still get melting and "wavy" edges. most work needs to be with 1mm and 2mm dia mills. Am using air blast to clear chips and cool.
ID:	43548   Click image for larger version
[IMG] code is Off
Calculating acceleration rates mcmmach General CNC (Mill and Lathe) Control Software (NC) 4 07-26-2010 07:55 AM
Calculating feeds and speeds using FPM and IPR Scalesoar General Metalwork Discussion 3 02-08-2007 07:58 PM
Feed rates & IPM ChristopherWood WoodWorking 6 10-30-2006 03:08 PM
Feed Rates rcheli Benchtop Machines 0 12-28-2005 10:34 AM
Rpm and Feed Rates Xeno General CAM Discussion 35 02-23-2004 04:06 PM
