Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 07-06-2007, 05:23 PM
bigz1's Avatar
bigz1 is on a distinguished road
What paint for perspex???
I am having problems painting Perspex. I have used a V cutter to cut football badges and using the backing plastic as a mask. The paint am using is acrylic Tamiya model paint. Unfortunately when carefully peeling away the backing plastic chunks of paint are lifting away. Undercost was used and light coats applied with an airbrush.
Is their a more suitable paint or do I require some sort of etch primer????
Old 07-09-2007, 10:53 AM
coltons customs's Avatar
coltons customs is on a distinguished road
ive never dealt with perspex but have had the same probs with others you can use a self etching primer but i have found that plastic adhesion promoter tends to work nicely such as and adhesion promoter they use on automotive bumpers to keep paint from peeling i found the stuff i used at the local auto paint store it either comes by the quart or in a rattle can hope i helped
"The best things said should be written in stone"
Colton www.coltonscustoms.com
Old 07-28-2007, 08:47 PM
DennisCNC's Avatar
DennisCNC is on a distinguished road
The best stuff is adhesion promoter called Bulldog. You can buy spraycan in walmart or autobody supplyer. Works great with plastic aluminum glass chrome.
You can spray bulldog and while its wet spray paint.
Dennis
[IMG] code is Off
Machine paint? Where to get? SRT Mike General Metalwork Discussion 5 10-28-2006 10:04 PM
Good metal paint wcarrothers1 DIY-CNC Router Table Machines 4 10-22-2006 08:44 PM
Best paint for CNC cabinet Karl_T General Metalwork Discussion 1 10-31-2005 10:56 AM
Paint Recommendation ChrisJ Vertical Mill, Lathe Project Log 4 10-06-2005 02:30 AM
Paint that oil will not affect ? Ken_Shea CNCzone Club House 14 04-27-2004 10:51 AM
