Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 04-18-2003, 09:45 AM
JSandSO's Avatar
JSandSO is on a distinguished road
perfect polishing with CNC machine
is it possible to achieve a perfect polishing on granite or marble with a CNC-machine or are you guys have to touch up the polishing by hand?
Thanks in advance
byebye
Juergen
Old 04-12-2007, 04:23 PM
tension is on a distinguished road
In my personal opinion there is no way a CNC will make a perfect polish. Any machined polish will leave lines. I've heard glory stories about how "this" tool or "that" tool wont leave the lines but I simply dont believe it. Granted you may have smaller lines that are less noticable but ultimately, they are still there. Nothing beats polishing the stone by hand, its craftsmanship, its an art. Theres nothing bad about the CNC polish, in fact, I did the kitchen and vanities in my own house on our CNC and I have no complaints whatsoever. Theres a definate noticable difference, but you have to be pretty anal about it to pitch a fuss.
If you are that worried about it then simply have someone run a hand polish over the work the CNC has done, or do that from the beginning and save your machine time.
Old 04-12-2007, 05:01 PM
HuFlungDung's Avatar
Moderator
Amateur telescope makers were frequently warned about 'zoning' caused by machine polishing their telescope mirrors. The trouble with a machine is that the repetition of a stroke is too perfect. Build a machine (or a program) that introduces a degree of randomized stroke length, randomized direction and inexact rotation of the lap, and you might have half a chance at getting a good job off of a machine.
I don't know if that applies to general polishing such as you need, but the underlying principle is likely the same.
Old 06-01-2007, 10:21 PM
Egar Twins is on a distinguished road
techniqiue and tooling....I promise it is possible some machinesa are made for it!
Old 06-03-2007, 10:55 PM
Making chips is on a distinguished road
There are some edges that you can polish with no lines. Flat (Z) profile on some machines (CMS Brembana machines will do this) can be osolated on the cnc to take out the lines. It also depends of course on the stone and the profile as to how the lines stand out. More complex profiles (ex. triple pencil) it is hard to see the lines. I put Santa Cecelia in my kitchen with a triple pencil edge, cut it on the machine, sealed it, and installed it without touching a hand grinder. It is possible. Also if you take care of your tools (keeping them dressed and calibrated) the lines can be left at a minimum.
Hope this helps,
Paul
Old 08-27-2011, 09:44 PM
T_Kiwi is on a distinguished road
simple answer is "no", best thing to do is finish on position 4 diamond and get the boys to finish by hand. osolation for flat edge can be achieved with no lines but lets face it, speed is the key here so again, finish by hand. I was invited to the company Ghines in Italy and was told that achieving no lines cannot be achieved, only minimising them can.
Old 08-28-2011, 08:27 AM
stonecoldcnc's Avatar
stonecoldcnc is on a distinguished road
Hi T_Kiwi I agree
I have also been to Italy and spoke to another major diamond tool manufacturer and they have said exactly the same as Ghines to you.
We now run only 4x diamonds and then get the boys to finish of the bench tops by hand. I know that some might not agree but over here in WA the standard seems to be much higher then in the US and our clients would just not accept a bad finish.
http://stonecoldcnc.com -> Over 1600 FREE DXF templates for sink, basin and lavatory cut outs for Granite and Marble countertops
Old 10-27-2011, 07:11 AM
Thanks in advance
byebye
Juergen
i dont care what anyone says, you cannot get a perfect polish from a cnc machine everytime. yes you may get one good one but its a lucky dip, as for polishing by hand, its not an art, its the rotatation of the pads that make the difference, the art is to make sure the aris or pencil round is even. oscillation works for a no line finish but try doing that for a pencil round or bullnose or lambs tongue if you disagree then you must be a salesman
Old 10-27-2011, 08:01 AM
I still agree with T_Kiwi,
although there is an obvious difference between polishing edge profiles or horizontal flat surfaces like draining boards, were it is possible to achieve a near acceptable polishing, at least on softer light colored granites but not so much on darker and harder granites. I also had good results on engineered stones with polishing draining boards but it took a lot of fiddling with the program settings to get near random movements for all tools and still cover all areas equally.
Old 10-27-2011, 11:29 AM
judleroy's Avatar
judleroy is on a distinguished road
I worked in granite for years. I can say that the first few polishes after a good setup can be acceptable if not perfect on the machine. The problem is that if your needing to polish 30-40 pieces a day with each one different the tools just can't keep a good enough finish. There's to many variables with both the profile tools and pollsters to stay consistent. If you need to get the work out you cannot afford the constant time spent readjusting the tools. I've yet to see software that can accurately account for all the variables. In my opinion you only use polishers to finish the flat edges inside of sink profiles. Anything else is a waste of time. There is no substitute for a good hand polish.
Judleroy
  #11   Ban this user!
Old 10-27-2011, 03:28 PM
ah well drain boards is a very different story, i have had great success with drain boards, the trick to a perfect polish on any material is making sure you use 2 surface grinders, first on to take the bulk and second one to take 0.1 off and always keep the second one for that purpose only. i can answer questions later but off to work now
  #12   Ban this user!
Old 11-12-2011, 10:24 AM
SteinmetzKramer is on a distinguished road
Of course it is posible to polish granite perfect.
I use for this a, Master 35Plus with 200mm polishing head but look self
http://youtu.be/uOZT-ek3BLw
[IMG] code is Off
polishing stone with CNC machine JSandSO Glass, Plastic and Stone 7 06-05-2007 11:01 PM
My First CNC Machine, Mr. Chips Mr.Chips DIY-CNC Router Table Machines 81 02-10-2007 10:04 AM
Heads Up - Article about building CNC Milling Machine samualt CNCzone Club House 3 06-13-2005 03:43 PM
My CNC Machine and Questions Davedbq General Electronics Discussion 2 01-22-2005 10:14 AM
World's Cheapest CNC machine @ $100?? SuperCharg DIY-CNC Router Table Machines 2 09-15-2003 08:39 AM
