| Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here. |
| Cutting Acrylic I'm starting to do more acrylic work at the shop, and was wondering whats the best way to cut acrylic? Mainly sheets, anywhere from 1/4" to 1". I'll be doing this on either a Haas VF2, or VF7. Btw, I should be more clear when I say cutting, but milling parts out of the sheets. Thanks in advance! btw I wasn't sure where to post this, so please move the appropriate section if needed. |
| I moved your thread here from the announcements section. ![]() Cutting acrylic is not too bad. Use sharp cutters, avoid excessive heat, (melted plastic built up in flutes makes for nasty burrs! ), and try to cut into the material to avoid chipping as the end mill breaks out.HTH 'Rekd
__________________ Matt San Diego, Ca ___ o o o_ [l_,[_____], l---L - □lllllll□- ( )_) ( )_)--)_) (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Make sure that your acrylic/plexiglas is a cast plastic not extruded. Extruded is noted for the melting and wrapping around your endmills. I cut cast acrylic with a 1/16 bit 30-40ipm rough with 15 ipm smooth pass. I get great results. Bill |
| Acrylic I don't know much about acrylic. How do you tell if it is cast or extruded? Marv |
| Re: Acrylic
Most of the plastic places will have a scrap bin that they will let you rummage through for a dollar a pound. Bill |
1/16 at 30-40ipm? How deep? |
| I cut about 0.1 each pass. The smooth pass takes off 0.02...with great results. I've never cut wood or aluminum on my machine...only acrylic and HDPE. I'm entertaining an idea of making a collet out of aluminum for a larger router than my rotozip. Bill |
| May want to take a page from new hermes book and use a large laminate router with a 3" wheel on the end - they transfer the rotation using a rubber belt to the small spindle head increasing the rotation at the spindle by 2x the router speed. I like this system as the bits are the only thing that get sacrificed when you bite into something. If the bit gets lodged the rubber band will break or spin freely without damaging the router. If you need pics of this lemme know soon - I am getting the NH machine out of my shop in exchange for a laser. Will only have it for another cpl weeks I hope. Like Rekd said cut into the material - commonly this is done by reversing your curve in your generation program or selecing climb cutting if you have the option. This leaves all the melted chips on the side of the waste substrate not your cutout piece, you will still have some flecks that need to be knifed off but the final edge can be cleared again using an oxygen torch and light passes.
__________________ Worry about success, failure takes care of itself. |
| Hey guys what material for lithopanes, I had read acrylic so bought some on ebay called called plexiglass acrylic (clear) but when I cut the picture doesnt look anything like a lithopane! shoulf it be colored? what color, also read corian is good but isnt that stuff solid color so no light gets through and its thick from what I saw at HD any in put would be greatly appreciated
__________________ Learn from the mistakes of others you can't afford to make them all yourself! |
#10
| I have not milled acrylic but am familiar with polycarbonate, I find it works best with coolant. Considering you are doing this in a VMC maybe you could give it a try and then it won't matter if it is cast or extruded.
#11
| Corian is translucent, the thinner you cut it the more light will show through. It would need to be backlit, though.
#12
). An overload sensor or something?
__________________ thanks Michael T. "If you don't stand for something, chances are, you'll fall for anything!" |
| Having trouble cutting aluminum sheet | fastturbovet | General Metalwork Discussion | 40 | 06-14-2005 11:33 PM |
| cutting Parts from a plate... need some tips | Bird_E | General Metalwork Discussion | 2 | 04-09-2005 11:40 PM |
| Cutting metal | signIT | DIY-CNC Router Table Machines | 2 | 02-20-2005 12:14 AM |
| CNC router deflection calcs and cutting loads? | Linus | DIY-CNC Router Table Machines | 1 | 09-10-2004 11:08 AM |
| Do you account for climb cutting in G code? | fyffe555 | DIY-CNC Router Table Machines | 12 | 11-06-2003 08:21 PM |
