Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 04-07-2007, 07:46 PM
ariel 1 is on a distinguished road
Question Need Help Cutting Glass!!!
I have been doing stainglass designs for awhile, and am curious could you a
cnc to cut designs, like a plasma cutter?
If so what kind of tooling would you have to use?
Would you have to use a waterjet? Is that the only option?
I have been stumped!!!
HELP!!!
Old 04-08-2007, 05:20 AM
Laser.Tech's Avatar
Laser.Tech is on a distinguished road
Smile
I once saw a machine automatically cutting curved pieces out of a large glass pane. I didn't get too close a look at it, but it appeared to be using a scoring technique. I dont know much about cutting sheet glass, but I cant think of any reason this couldn't be done rather easily with a CNC setup. How do you currently do it (technique)?
Laser.Tech
Old 04-09-2007, 09:47 PM
DennisCNC's Avatar
DennisCNC is on a distinguished road
I never seen glass cut on a cnc but seen a few pictures of the machines and it looks like they use a wheel cutter to cut sheets like you would by hand.
Dennis
Old 04-09-2007, 10:37 PM
Laser.Tech's Avatar
Talking
Dennis,
If a machine with a spindle that can be oriented in conjuction with the direction of machine travel is used, it seems it would work fine. I'm still a beginner , but I believe this is a common feature in many CAM programs. I've seen it mentioned several times, usually in reference to doing CNC cutting using a knife. You would be dolng the same thing only using a scoring wheel instead .
Are you thinking about building your own system or shopping for one? I'm designing my own right now, looking at features, and cutting glass would be AWSOME! You've got me thinking ....
Laser.Tech
Old 05-31-2007, 06:26 PM
Matt29c's Avatar
Matt29c is on a distinguished road
Oh Oh I know...
Hah! Just as it was I saw a program on TV the other night about large scale glass production and they quickly went over the machines they used to cut the glass and there was basicly two options 1: FlowJet (Water and Garnet flakes) or 2: A CNC machine with a diamond tipped scoring tool on the business end. The FlowJet seams kinda unrealisitc for a small shop (but it would be fun) and the 2nd option could be ghetto rigged from a glass scoring tool which isn't hard to come by.
Old 05-31-2007, 07:33 PM
sdopp is on a distinguished road
If scored glass on a small cnc with a diamond tip burr, didn't work very well when I went to break it so I gave up.
Old 05-31-2007, 11:11 PM
silverfoxx03 is on a distinguished road
Diamond tooling for sure--lots of choices out there.
let me know how I can help
Old 06-17-2007, 08:38 PM
recoton is on a distinguished road
Our shop purchased 2 glass cutting machines from a guy in new jersey and we have templates we made from a cnc router.the drawback for cutting the glass was we couldnt cut intricate designs so we milled bigger radiuses in the
mirrors we do.
Old 06-18-2007, 07:02 PM
Ron111 is on a distinguished road
recoton,
Could you post a couple pic's of the glass that you cut and the machine setup that you use. I make a small periscope and have to cut mirrors that are .980 X 1.35 out of .100 thich mirror sheets (8X10) and I have made a couple of jigs that help a little(I still score by hand, but it would be nice to automate it where I don't have so much waste of time and material)
Thanks,
Ron
Old 06-18-2007, 08:27 PM
basicly the machine works like a tracer it has a bottom table and a handle on a back spindle,about three pieces put together on bearings and a slot to follow the contour of your template.the diamond cutter also swivels around.the most important part is a little air pressure on the diamond cutter so it cuts deep enough but you can only trace it once or the score gets messed up.Ill try to get a picture,didnt have luck on the internet .
  #11   Ban this user!
Old 06-19-2007, 07:23 PM
brokenlaser is on a distinguished road
Laser, easiest way, but you need an industrial Co2 to do it proficiently. I cut glass and synthetic crystal all the time in our shop. The key is to put enough heat into the glass to relieve the stress caused by the cutting process.
  #12   Ban this user!
Old 06-20-2007, 07:28 PM
Matt29c's Avatar
Yeah "Lasers" are looking to be contender #1, But the down side is COST...a homebuilt laser is going to draw alot of power (for cooling,and such) and the CO2 tube is going to run anywhere from $350USD to $900USD and then you have to make the powersuply,optics, and all that jazz. If you make it wrong alot of bad things can happen. And a prebuilt laser in the 240W range (glass cutting) from the quotes I got about $5,000USD and then you have to ship the 35lbs monster to you. I think I might make a laser even though I have no experience I found quite a few websites focusing on homebuilt lasers.
Good hunting
[IMG] code is Off
Glass DLMACHINE Glass, Plastic and Stone 6 08-22-2011 10:07 PM
glass cutting table cristian gabor Mechanical Calculations/Engineering Design 5 05-29-2009 02:51 AM
Help with Glass mermaid1015 Glass, Plastic and Stone 15 05-12-2009 11:08 AM
Glass Cutting Router mistahxjason DIY-CNC Router Table Machines 12 03-18-2007 09:08 PM
Glass cutting gabi68 DIY-CNC Router Table Machines 7 11-11-2006 09:34 PM
