Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: I need suggestions for outdoor sign material.
    Dec 2006
    Hi guys.
    I'm going to rebuild the letters for our neighborhood entry sign. Pictures of the old sign are below. I will pressure wash the bricks and cut new letters.
    My question to you smart material guys. What kind of plastic would you recommend for these replacement letters? Letter height is currently 15 inches.
    Thanks.
    Dave
    Attached Thumbnails Attached Thumbnails I need suggestions for outdoor sign material.-imga0646.jpg   I need suggestions for outdoor sign material.-imga0643.jpg   I need suggestions for outdoor sign material.-camelot_signage.jpg
    Gold Member High Seas's Avatar
    Sep 2003
    Malaysia/Australia/NZ/USA
    I suppose you considered using the cnc to cut a mold - then cast the letters? I ask, as that opens a new set of questions for materials -- as opposed to milling them out of a plastics. Then you'd be into paint and finish too
    They could be cast in any number of resins, solid or hand lay-up as hollow backs with mounts cast in. Justa sideways view you might consider. An added advantage - you'd probably store the molds for replacement when they go "walkabout."
    Jim
    There are some really awesome cast resin products coming outta China that are extremely detailed and highly polished. Not you'd choose that - just an example of the material processes.
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Dec 2006
    Sign Material
    I personally would use 18 lb Sign Foam. Nice to work with and uses polyurethane glue to stick to the bricks. Once primed, any type of paint can be used.
    Brian
    Dec 2006
    Brian, Where would I buy 18 lb sign foam? Is 18 significant to density, such as 18 lb/cuFt?
    Jim, Where would I buy the resins you speak of. What material would I use for the mold.
    I like both options, and thanks to both of you for your response.
    Dec 2006
    Foam Sources
    Try this one
    http://www.signfoam.com/
    Brian
    Sep 2003
    Glidergider -
    It can be a bit of a fiddly process -There are heaps of sources on the web you could source/get the resins - or find a auto/boat store for the higher price!
    For the molds you could use mdf, foam etc - but then need to prep it with fillers, sand it to finish - use a high-build primer, then wax (all to make sure it will release from the mold), then, layup resin and fiberglass. OK, Ok - it sounds like a lotta work for one-off!
    Or - go get the sign foam Like Brian suggested and finish it with the right stuff! You could work the mounts in the back side as needed for blind fastening to the brickwork - but may need resins for mounting/reinforcement. (I'd guess the web sources are as good as anyone but not so cheap - a quick look:
    http://www.denversignsupply.com/cate...me=Sign%20Foam)
    I suppose you could cut using other low density foams and vacuum bag like a wing (lots of guys building things like that here too. That way you could get a good finish and outdoor - ability too at less cost. I'd probably try using blue foam - glued up to thickness then cut on the cnc.
    Be sure and save your files to recut and replace as needed! Less storage than molds! Any way you choose - it'll be a nice feature to have back on the bricks!
    Jim
    Dec 2006
    Jim,
    Thanks for the good ideas and the source of signfoam. Yes it is pricey but I'd like to try that material someday.
    Dave
    Registered judleroy's Avatar
    Dec 2006
    If you have a local plastic supplier I would talk to him.
    Or you can look online for a plastics supplier like www.usplastics.com . Look for something that is UV stabalized.Probably a polyethylene. The material can be purchased in full sheets half sheets or quater sheets most of the time. It would probably be between 50
    to 100 dollars for something like this. Just A suggestion
    of what I would use.
    Dec 2006
    Judleroy,
    Thanks for the links. I've bookmarked it for later reference.
    Consider this. I just found a surplus store that has lots of $3 12x18 inch white cutting boards. I don't have any idea what composition the plastic is except, its not HPDE, Delrin or UHMW.
    A similar cutting board at the kitchen store labels it a Poly plastic. Thats all. Its plenty strong and almost a half inch in thickness.
    I don't know its resistance to UV.
    Any thoughts?
    Dave
    Dec 2006
    Glidergider
    Sorry I did not see you're reply sooner. The Cutting boards you are looking at are almost certainly not UV
    protected. UV protection is almost exclusivly used for
    materials that are designed for outdoor applications.
    Without this protection over time the material will discolor and crack. Sunlight also causes it to degrade
    and break down. If you can keep the pieces out of direct
    sunlight most of the day it may still last for years. I beleive crylon makes a paint specificly for plastics. Try
    seeing if this kind of paint is UV resistant. If it is you
    should be fine with those $3.00 cutting boards. If they
    are white and somewhat flexable they are probably some form of HDPE or LDPE even if there not labeled
    that. They are probably made from recycled milk jugs and such. Good luck.
    Judleroy
    Oct 2006
    India
    Quote Originally Posted by Glidergider View Post
    Judleroy,
    Any thoughts?
    Dave
    hi,
    the material you say must be Polyrpropylene(PP) and it is pretty UV stabilized. Or else check for any Polyolefine supporting paints, wherein you can paint the letters with black or any UV resistant bright colors. This material has to be cut with high speed band saws, or else the edges wont come sharp. Good luck!
    Chan Luci, Techie
    www.custompartsonline.com
    Registered 11bravo's Avatar
    Mar 2007
    Check this page out:
    http://k-mac-plastics.com/uhmw-uv-sheet.htm
    UHMW UV Resistant Sheet and never having looked for the stuff before, I'd say not too badly priced.
    Not as inexpensive as the cutting boards though.
    Greg
  • Page 1 of 2 12 LastLast
    1. Material selection for cd storage
      By dberndt in forum Mechanical Calculations/Engineering Design
      Last Post: 10-04-2005, 05:40 PM
    2. Cad Pgm. Enough sign up and get it free
      By Al_The_Man in forum Product and Manufacturer Announcements
      Last Post: 06-23-2005, 10:16 AM
    3. Plus sign next to names?
      By DAB_Design in forum Forum Questions or Problems
      Last Post: 06-08-2005, 11:26 AM
    4. Plastic Sign Material - Where to purchase?
      By edbo68 in forum DIY CNC Router Table Machines
      Last Post: 04-26-2005, 11:59 PM
