| Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here. |
hi guys whats the best way to deburr acetal/delrin after it has been milled I am using scotchbrite pads at the moment but that is no good on intricate shapes all help appreciated acidcustom |
| I use a standard utility knife blade(stanley). But not in the traditional way.When they stamp the blades it produces a slight burr(not the cutting edge,the angled sides) on one side.You can see it if you look close.Hold the blade in your fingers similar to holding a pencil,with the burr away from you.Place it up to your part at about a 45 deg. angle and push it away from your other hand. Hard to explain on the puter but it works great.I can take a pic if your you want. |
| There's a great burr tool made by Shaviv, a ceramic blade, that I use a lot for teflon, and it doesn't dig in or gouge when used carefully. I didn't think it would work, but it has turned out to be incredible for really soft stuff. It does teflon and delrin equally well. For complex shapes, have you thought of dry ice and a tumbler? Years ago we tumbled punched dense foam rubber parts with an abrasive and chunks of dry ice. The flash from the punching operation came right off. (they were slot car tires....!) ....a place to start.... http://www.shaviv.com/shaviv-pdf/SHA...05-English.pdf |
| What media for deburring aluminum | warpedmephisto | Mass finishing equipment/media/stratigies | 2 | 08-24-2006 02:56 PM |
| Deburring | 9566317 | Mass finishing equipment/media/stratigies | 2 | 05-05-2006 12:28 AM |
| Deburring: Grinding vs Sanding? | InspirationTool | General Metal Working Machines | 6 | 12-09-2005 02:40 PM |
| How do you automate deburring? | Swami | General Metalwork Discussion | 21 | 10-27-2004 03:06 PM |
| Thread deburring | tex | G-Code Programing | 23 | 05-12-2004 07:27 PM |
