Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 02-10-2007, 04:56 AM
lightorber is on a distinguished road
Question Need help finding or designing for acrylic machine
HI,
I am trying to design a real basic CNC that will basically cut through a 3mm piece of Acrylic in a straight line and being able to place these at a certian distance apart. Any ideas on this simple yet necessary concept. I may expand later to cut round holes and patterns, and predrill holes.
Old 02-10-2007, 09:08 AM
OCNC is on a distinguished road
Originally Posted by lightorber View Post
HI,
How about some more info? What size are the pieces you wish to cut (determines the foot print of the machine)? It sounds like you won't need much Z travel (cutting sheet goods exclusively?). What do you have for a router? Does acrylic need to be cut wet (with a lubricant of some kind)? What's your spending budget like?
Chris
Old 02-10-2007, 10:28 AM
ger21's Avatar
You should be able to do it with pretty much any router or mill. What you're asking for are basic operations.
The only issues you would run into would be spindle rpm (too high can result in melting) and, as was mentioned, whether or not you need to use a coolant. Coolant wouldn't mix well with a wood framed machine.
Old 02-11-2007, 08:32 PM
Talking Size of work pieces
Thinking I might want to do plastic and metal but might make two seperate one for plastic and one for metl. size of plastic is 10 inches by 10 inches at the biggest. Am planning to make metal frame out of old L shaped steel shelving so it water proof and won't vibrate and afect accuracy. Hope this answered the questions needed for know how. Proberbly use coolent that runs onto work, through a filter and then cycles back to use again if anyone thinks that would work. Also I thought that I could make the work area capable of working up to 20 inches by 20 inches.
Old 02-12-2007, 02:42 PM
You might be well served to build a small machine using wood and relatively inexpensive components. This would allow you to get some hands-on experience of what is necessary to build a machine and it would also allow you to ask more specific questions. Take a look at John Kleinbauer's website for some ideas.
[IMG] code is Off
Help finding the right machine Jay Kyle CNC Machining Centers 0 02-06-2007 02:00 PM
Designing a CNC tequilaguru General CNC (Mill and Lathe) Control Software (NC) 3 01-16-2007 04:24 PM
designing a mill veteq Mechanical Calculations/Engineering Design 16 09-18-2006 04:34 PM
Designing my next mill in solidworks. radicooldude Benchtop Machines 14 04-22-2006 03:06 AM
designing my first CNC georgebarr DIY-CNC Router Table Machines 6 07-01-2003 05:40 PM
