Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 01-30-2007, 11:03 AM
RWinter is on a distinguished road
Frosted Acrylics from a Lathe
I'm in a CNC course at my school, and I came up with an idea of making a light-up chess set. The pieces would be turned on an Emco Compact5 PC late. I was wondering the best way to achieve a frosted effect from clear acrylic stock, and what brands you would recommend, as well as any tips you may have to share.
Thanks in advance.
Old 01-30-2007, 11:24 AM
One tip: Use cast acrylic not extruded. Do a bit of Googling to find out about annealing the pieces after machining; this is not difficult and may even be possible in a regular cooking oven with care.
Old 02-05-2007, 11:47 PM
chan luci is on a distinguished road
if dont turn the rod for a smooth finish and use a sand paper, obviously, the finish would look frosted!! Why is this difficult?
Chan Luci, Techie
www.custompartsonline.com
Old 02-06-2007, 08:21 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
*agrees with Geoff on Cast, not extruded* extruded includes inclusions, but with cast the impurities (hence inclusions) settle to the bottom of the cast and can be skimmed off.
If going for a "nicer" frosted finish I should sand blast it instead of sandpaper... may give you a more uniform finish. Obviously don't do this on your machine cos the stuff gets everywhere.
Get a hand drill (like the old ones our dads used to have), stick a countersunk hole thru a disk with a bolt to hold in the drill chuck, stick the drill in a vice, double sided tape the part onto the disk and turn with one hand and sandblast with the other
Remove Double sided tape residue with WD40. Clean with Ethanol (not Acetone).
Good cast Acrylic (optical Quality) can be obtained very reasonably in various diameters from RS Components here in the UK.
www.rswww.com.
I use that stuff for optics
I love deadlines- I like the whooshing sound they make as they fly by.
[IMG] code is Off
CNC "KIT" for 8x12 8x14 mini lathe - or cheap/small CNC lathe? tinkering Mini Lathe 15 05-05-2011 06:59 PM
Convert a lathe to a cnc lathe Tompie General Metal Working Machines 1 09-21-2006 09:41 AM
Lathe Comparison - Best small lathe for CNC acondit Mini Lathe 48 03-23-2006 08:10 PM
Anyone have a mini cnc lathe or medium sized cnc lathe nymachinist Mini Lathe 6 01-23-2006 09:36 PM
New Micro lathe built by me (my second lathe) Stevie General Metal Working Machines 15 11-03-2004 04:56 AM
