Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 01-22-2007, 04:17 PM
Aaron92SE is on a distinguished road
Cheapest and cleanest way to cut 1/4" G10? Waterjet? Laser?
I am cutting a part out of a sheet of 1/4" black G10 from McMaster Carr.
I believe waterjet will be the cheapest way to cut out my prototype. But I am scared of delamination and a bad edge. Maybe some minor hand sanding will get rid of some of the small dimples or blowouts caused by a waterjet.
My other option would be to laser cut the G10. How bad will scorching be? Is there anything you can do to minimize scorching? Like adding nitrogen? If there is scorching, will sanding diminish the black finish on the G10? I don't want to sand it and have the black G10 turn to a greyish white finish on the edges.
And last and most expensive is to CNC cut it with a diamond tool. The setup costs are the highest in this situation. So I am looking for a cheaper way to produce this part.
Does anybody have any experience cutting this material with a waterjet or laser? What things can you do to ensure a clean edge?
Can anybody reccomend a company that can make my prototype using a cheaper method?
Here is a picture of my drawing. You see how many curves there are and the waterjet might have trouble with lagging on some of these inside radii.
http://www.iwdwebdesign.com/bbs/Inta...pacer-Half.jpg
Old 01-22-2007, 05:49 PM
Gold Member
lerman is on a distinguished road
Have you considered cutting it with carbide?
Kenneth Lerman
55 Main Street
Newtown, CT 06470
Old 01-22-2007, 05:52 PM
Yes, but the setup costs are usually very high with all the companies I have submitted an RFQ to.
I am hoping to find a way to waterjet without delamination problems. Or to laser cut without scorching problems.
Thanks for the reponse.
Old 02-18-2007, 11:05 AM
Gold Member
Caprirs is on a distinguished road
I worked at a place where all we did was G10. We used carbide cutters but the tools were so dull after one cycle (about 1/2 hour), that they were thrown into the recylcing bin after one use.
Most shops do not like cutting such materials because the G10 is highly abrasive and will destroy the mill's ways and bearing surfaces quickly. The stuff doesn't really cut, it pulverizes like graphite and chalk so the powder either goes airborne, or it has to be run wet and contaminate the coolant tanks. When it gets into the coolant system, it tears up the seals in the coolant pumps.
I'd recommend the waterjet. I don't know how a laser would do.
Old 02-18-2007, 02:37 PM
ViperTX is on a distinguished road
What are it's intended uses....why G10 and why 1/4 inch thick?
Old 02-18-2007, 05:25 PM
Thanks for the reply. This is an older thread. I have since figured out the best and cleanest way to cut G10. But you need to use coolant with a diamond bit.
With waterjet, there is a chance of delamination if the company doesn't know what they are doing. But there are some companies that have figured out how to cut it without problems with a waterjet. It's just a little tricky.
And with laser cutting, it will scorch the edges. A masking layer might help, but laser sometimes gets a little expensive.
ViperTX, I am creating a new product using 1/4" G10. I can't go into detail at this time. I'm sorry.
Old 02-27-2007, 10:34 PM
kf364 is on a distinguished road
Where I work now all we do is G10, G11 with milling machine, lathes using carbide tooling. also we use a water jet with very little problems with delamination. I have only been machining this kind of material for 1 year.
We also cut all kinds of plastics.
[IMG] code is Off
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 01:15 AM
A Guide: Plasma vs Laser vs Waterjet vs EDM InspirationTool CNC Plasma and Waterjet Machines 25 07-20-2009 02:43 AM
Vertical system "jerks" and "bangs"?? REVCAM_Bob Servo Motors and Drives 5 06-12-2006 10:09 AM
EDM, CNC, PLASMA, Foam Cutter, WaterJet, Laser ??? trangt143 Haas Mills 2 02-02-2006 11:22 PM
CNC sheet cutting comparisons: laser, router, punch, waterjet, wire edm... InspirationTool CNC Plasma and Waterjet Machines 3 06-24-2005 02:22 PM
