Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 11-18-2006, 09:01 PM
DennisCNC's Avatar
DennisCNC is on a distinguished road
My DIY Stone Router
Here are some pics of the stone router I buit ~6 month ago. It has a 3hp 3ph motor with a VFD in a separate box. The hight adjusting knob is attached to a sproket that rotates four other sprokets by chain with threads in them for the four support bolts. Still running strong even after falling a few times.
ID:	25871   Click image for larger version
ID:	25872   Click image for larger version
Dennis
Old 11-18-2006, 09:18 PM
ViperTX is on a distinguished road
Any more details....what are you using for the surface that rubs on the granite?
Old 11-18-2006, 10:11 PM
DennisCNC's Avatar
Ask the Q's and I'll answer. I have white plastic screwed to the bottom of the lower aluminum plate with a channel machined in the plastic so when it mates to the plate the water gets distributed to the little holes that are drilled through out the bottom of the plastic so it floats of water. But it still cratches the surface, so we put white flashing plastic on the stone then the router.
Dennis
Old 11-18-2006, 10:17 PM
What is the RPM of the motor....how is it geared down or up....is the drive mechanism a belt, chain or gear? Is the spindle of a fixed height, if not then how is it adjusted?
Old 11-18-2006, 10:37 PM
DennisCNC's Avatar
The motor is 3,600 rpm, it has a gear belt 1:1, I should have made it like 1:3 or so but it works fine like that. I crank up the VFD to 120Hz and it buzzes away all day.
The spindle is fixed but the entire router is supported by four 1/2 bolts to the lower plate and as you turn the white knob all four brass nuts rotare and the router mover up or down.
I'll see if I have pictures of the inside.
Dennis
Old 11-18-2006, 11:18 PM
DennisCNC's Avatar
It has four of the brass sprokets below and the four supporting bolts go through them.
ID:	25884   Click image for larger version
Dennis
Old 11-19-2006, 12:03 AM
So at 120 Hz....is the motor speed 7200 RPM?
Old 11-19-2006, 01:40 PM
DennisCNC's Avatar
^^^ Correct. Not sure how long the motor will last like that, but it just gets ~130*F, it is a TEFC motor so they are make to run hot.
Dennis
Old 01-21-2007, 09:29 AM
stone1925 is on a distinguished road
Hello
I was just browsing around when I came across your stone router. Where do you get your stone router bits from.... I will get back to cnc routers now
Old 01-21-2007, 05:41 PM
DennisCNC's Avatar
In US I bought a set of bits from Helix tools, Mark Smith is the one I spoke with.
Dennis
  #11   Ban this user!
Old 02-16-2007, 03:56 PM
Granite Guy is on a distinguished road
CNC Router
Anybody looking for a CNC router???
  #12   Ban this user!
Old 02-17-2007, 07:05 PM
DennisCNC's Avatar
Sure, whats the price?
Dennis
[IMG] code is Off
