Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 10-30-2006, 12:46 PM
tsjim's Avatar
tsjim is on a distinguished road
z bavelloni egar 320
does anyone have a source for the micro switch used in the probe assembly
thanks Jim
Old 11-07-2006, 10:14 PM
hotrodcnc is on a distinguished road
eucher or eucker
ng1fo-510
011985 made in germany
look on the net
Old 11-07-2006, 10:18 PM
euchner google it
Old 04-13-2007, 09:27 AM
tension is on a distinguished road
Little topic change =)~
If anyone else is using the same machine I'd love to pick at your brain about it. Thanks in advance
Old 04-13-2007, 02:23 PM
tsjim's Avatar
z bavelloni egar 320 brain pick
I`am not the operator, but do the repair and maintenace on it.
be glade to help any way possible
tsjim
Old 04-13-2007, 03:14 PM
Thank you !
I have one question for you because I can't find anything like this in the maintenance manual. Next to the vaccume pump there is an air tank that collects water and next to that theres another tank with the air filter. I dont know or even understand why but sometimes, it seems that the vaccume pump is letter oil into the air filter tank. It does not happen when the water/air tank is full or anything but randomly. Do you by any chance know why this is happening and if so what I can do to stop it?
Thanks again !
Old 04-16-2007, 02:08 PM
tsjim's Avatar
zbav oil
having rebuilt the vacuum pump 2 times, there is no reason oil should get that far back into the system, water should be drained every time the pump is turned off and water level in the pump should be checked daily,and drained as well, the pump can overfill its self with water/oil
from normal use.
we have an ocienian that is used most of the time and the vacuum pump
has a separate tank (30gal) used to keep water out the system.
much better design than the z bav, how old is your machine?
thanks tsjim
Old 04-16-2007, 03:43 PM
My machine is about a year and a half old. Not sure about model wise and their upgrade rate but thats when we got ours.
There any chance you could snap a few pictures of that setup you have?
To be perfectly honest with you. I went to college for web design and interactive media design. I took this job because I have an aptitude for learning software quickly and the machine part just came with reading the instructions and a few lessons. So basically, when it comes to the engineering portion of the machine I'm limited. I'd be greatful if you had any more tips on how I can better the efficency of my machine.
Thanks man =)
I appreciate it
Old 06-01-2007, 10:06 PM
Egar Twins is on a distinguished road
I have worked extensively with bavellonis and Northwoods alike and hold very high stature with both companies...the Bavelloni possess a dry pump which has a water seperator and a dry pump no water allowed!!!! If you back flush your system by mistake....linking the float and vac cup prots together by accident....oil can get blow back into the filter....also if you suck some water up into thzt badboy, stuff gets funk and the whole system acts weird...depressurizes and oil leaks back into the water seperator....if this happesn you need to change the vac oil...its is contaminated and your measureble vacuum -pressures will indicate this...
Jimbo
Old 01-18-2008, 04:36 AM
capo nord is on a distinguished road
Hi everybody!
do you still have problems with the pump? maybe I can help. I was a Bavelloni CNC technicain.
Fabio
  #11   Ban this user!
Old 01-18-2008, 02:59 PM
tsjim's Avatar
edgar 320 zbavalloni
pump if ok,the machine is for sale.(cheap 40k)
we replaced it with an ocieania
thanks Jim
  #12   Ban this user!
Old 05-26-2009, 11:17 AM
Metrostoneworks is on a distinguished road
Milling(finger) bits for an egar 320
I have had an Z Baveloni egar 320 machine for about 4 years now and i have figure most thing out about this machine. but recently i have been having a problem with finding a good milling bit. i have tried just about everything and yet to find one fast or stron enough. any one have any suggestions as to what is the best milling tool for this machine. is there one that would be better to use on dark stones compared to the lighter softer ones? anything you could give me would be a great help.
[IMG] code is Off
