Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 10-18-2006, 06:32 PM
Miata2k's Avatar
Miata2k is on a distinguished road
Have you ever machined Trex Decking?
I was at home depot the other day looking for a sheet of 1" MDF. I couldn't find the MDF but I walked by some artificial decking material. It was about 1 inch thick 6" wide and 8' long, so I bought one for about $15.
I think this is the same stuff:
http://www.trex.com/products/decking/default.asp
"Trex is made primarily with recycled plastic grocery bags, reclaimed pallet wrap and waste wood."
I was just planning on using it for the pipe adjustment blocks for my cnc design, but I was wondering if anyone else had any experience cutting or machining this material. They say you can use it like wood. I just plan to cut out a few squares, cut a big hole in the center and drill and tap the 4 sides to I can align the gas pipe I'm using in my CNC design.
I'll post updates if I ever get a chance to cut the board. I've had it for over a week and I just haven't had time to get out the saws.
-Chuck
Old 10-18-2006, 06:43 PM
out**cold is on a distinguished road
Trex cuts like butter! I have made plugs for bolt heads on decks. likes to be cut with high feed rate. No airborn dust. I also made accessories for my hot tub, towel rack, cup holders. I used heli coils if you need to tap it. wood screws tend to split it. Go for it! the stuff is great to machine.
[IMG] code is Off
