| Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here. |
Hi Guys ! Don't laugh, but I'm having problems routing simple ABS. The cutter clogs up (melts) the ABS and breaks the cutter. I've varied spindle speeds, feedrates, cutting depths without any luck. I used a 2 flute endmill and got it buggered up in no time. Best result so far was with a 3mm single flute cutter, but I need to cut some profiles with a 2mm tool. Haven't had any problems cutting any other plastics or allu. Any (working) advice will be appreciated Thanks Fanie |
| I have had good success with ABS etc. Firstly I have found that the rotation speed on a 3mm cutter needs to be about 9000 rpm, ( I tried fast at 18K and all it did was melt everything back together ) secondly use an upcut spiral, downcuts clog badly " unless" you take lighter cuts ie 2mm deep. Set the feed to about 3500mm per minute and play with the dash pot controller to go slower or a bit faster, start on a bit of scrap, remember hot tools break easier, but it is normally the speed of the feed that causes most breakage. I also use an airblast cooler, look up exair on the web or basically connect a fine nozzle jet to your air supply and adjust it to continiously blow away the chips and cool the bit. Or buy a mist spray unit. Hope this helps chris f |
| Hey Fanie We are cutting ABS all the time and found that with a (1/8") flat 2 flute 7000 rpm 75 ipm .010 step 50% across works pretty good. Remember if you plunge on the part you will load the part with heat and will get a blob of melted plastic on the end of your tool, Also an air plast to remove the chips helps. |
