Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 01-03-2004, 11:22 AM
turkgeltz is on a distinguished road
etching glass or mirrors
Does anyone have any experience with doing etching in glass and how to do it? diamond bit? speeds and feeds? Wife wants.......
Old 01-03-2004, 11:52 AM
steele is on a distinguished road
I have no experience here BUT: Have you considered making a stencil over the glass and then blasting it with grit? Does she really need glass, could you use clear plastic?
Old 01-03-2004, 12:47 PM
BIG AL is on a distinguished road
Coat the glass with a layer of wax, lay your template over the surface and start punching thru the template with a sharp stylus, next use needle to remove the wax between the punch marks, coat the surface with sulferic acid, let sand and then wash off with lots of water.Tip, go to a Tandy's store and get some leather transfers and follow the directions. (this is what I do as I'am only able to draw flys). Best of luck! BIG AL
Old 01-03-2004, 01:16 PM
Thanks, I'll have to give that a try!
Old 01-03-2004, 01:32 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Geoff Williams, in his book CNC Robotics took the following approach:
1. Plot the image on the surface with a permanent marker that resists etching paste, He found that the Pilot Metalic Marker (extra fine) would work.
2. Then added a border around the plot with a wider version to prevent "spill over".
3. Let the ink completely dry.
4. Read the safety warnings on the paste.
5. He applied the paste with a small piece of wood (bet the caustic stuff eats up the metal bits in brushes)
6. He let it dry for 15 minutes (plus or minus based on brand of etching paste).
7. Wash off the paste and then clean off the ink with lacquer thinner.
There's been a lot of plus/delta said 'bout his book. But this looks like it might work!
You might find all the bits to do the same thing at a crafts shop (Michaels or JoAnns - chain crafdt stores) or a stained glass shop.
Jim
PS - if you want to buy the book - best bet I found was thru overstock.com
Old 01-03-2004, 02:15 PM
keithorr is on a distinguished road
Don't.
Sulphuric acid doesn't etch glass. Hydrofluoric etches glass. Very toxic.
Old 01-03-2004, 07:44 PM
High Seas's Avatar
Gold Member
ROGER THAT!
I did a quick teoma search and there are some good hits on MSDS (safety data) and other options/info on pastes etc. I'm still prone to purse the xyz pen and ink (read CNC) approach to glass work - haven't yet, but will soon - rather than deal with more bits, cutting speeds/feed rates, etc on a pretty tough medium!
Mind you I hand-dressed 2 marble countertops by hand - so an easy way is a better way!
BUT - chemicals require care!
Jim
Old 01-03-2004, 08:44 PM
The paste is a dilute floride based product. The thickener prevents splashing, and the low molar strength makes it safer to use than hydrofluoric acid.
The only problem with the paste is the etch can look patchy. Some areas more frosty than others. Reapplication doesn't always solve the problem.
Commercial glasses etch differently depending on the chemical composition of the material.
Most shops use sandblasting equipment. A fine grain of aluminum oxide with produce a lightly textured frost, closest to an acid etch.
Silicon carbide is much harder, and knocks very small chips out of the glass. (Easier to see with a magnifying glass.) Silicon carbide grit is better for deep carving.
Old 01-03-2004, 09:19 PM
DLMACHINE is on a distinguished road
What about milling glass? Can it be done?
Old 01-03-2004, 11:01 PM
Konrad's Avatar
Konrad is on a distinguished road
Would a Dremmel tool with a diamond bit work?
Konrad
  #11   Ban this user!
Old 01-04-2004, 01:04 PM
Well your right, I feel even dumber than usual. Sulfric I used to etch metal, not glass, same method only different acid. My first thought for acid would have sent everyone in orbit as it only comes in a wax container. I do remember a shop that used sand in a unit that looked very much like an air brush, but the guy that did the brush work was a true artist. "Anyway this group proves that this is the best site on the web for solid info."
  #12   Ban this user!
Old 01-04-2004, 07:45 PM
What if I wanted to make a 3D object out of glass how would you do this?
[IMG] code is Off
Glass DLMACHINE Glass, Plastic and Stone 6 08-22-2011 10:07 PM
milling glass corpse Glass, Plastic and Stone 12 07-31-2007 09:47 PM
anilam glass scale incorporaton johnd General Electronics Discussion 1 05-05-2005 10:09 AM
Spindle choice - Glass CNC digital Machine Problems, Solutions , Wireless DNC, serial port 3 10-30-2004 12:37 AM
Forum for Glass and Stone machining JSandSO Machine Problems, Solutions , Wireless DNC, serial port 4 04-17-2003 08:40 PM
