Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 07-06-2006, 01:11 PM
Fadal Error is on a distinguished road
Drilling Lexan / Polycarbonate
I just wanted to throw out something I learned on a recent project. I figured it could be helpful to anyone like myself who may not know where to start.
I had to drill a bunch of 1/32 holes in a Lexan part and I got a tip that I could run it a lot faster than I had planned to.
3000 rpm
G83G99Z-.54R-.29Q.03F15.
The feedrate and peck depth was much more than I thought I could get away with. It saved me a lot of time.
Old 07-06-2006, 02:19 PM
*Registered*
lakeside is on a distinguished road
with flood coolant you should be able to go 2X-3X fast feed rate
Old 07-06-2006, 02:23 PM
I will try it next time. I have very little experience drilling small holes. I used a HSS drill this time. Is your suggestion based on using a carbide drill?
[IMG] code is Off
