Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 04-23-2006, 08:18 PM
MechMike is on a distinguished road
GLASS- Edging & Bevelling in CNC
Hi Members ,
I am new to the group, I would like to know if anyone has any knowledge on GLASS- edging & bevelling...using a CNC-BOB.. Brembane machine.
-Mainly the use of Bevelling & Edging Disc on tool Magazines.
-How to set up the Rapid speed and Feed speeds as per glass size/ thickness...eg:3mm ,5mm.10mm...19mm...etc....NE-
Mike
Old 04-01-2008, 08:53 AM
mika28au is on a distinguished road
"BOB" is this a CMS techno-metal cnc? if it is I'm pretty sure it's the big brother to Junior Technometal cnc which is the one I've been using for quit a few years now. as far as rapid and feed rates go "rapid" = travel between machinings so it can be very fast & "feed rate" = is the actual machining travel so it all depends on the tool and process you're doing i.e routing is usually around 450mm pm @ around 10 000 -15,999 rpm, and the diamond and polishing feeds usually upto 2000mm pm for 4mm - 6mm thick glass and around 1200mm pm for 8mm and up @ no more than 5000rpm. it really depends on how much glass you are taking off per pass one hit. as far as 3mm goes I wouldn't waste my time it's very brittle and easy enough to work with by hand.
what year model is the machine and what software does it use.
here's a sample of some side projects I've done
http://weekendoutdoors.awardspace.co...20waterjet.htm
[IMG] code is Off
