Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 04-10-2006, 09:32 PM
btimike is on a distinguished road
retrofit wood router for corian
Hello I'm new to the site and have a question about getting a cnc router
to cool with water. i'm a cabinet builder with some interest in using older
cnc for cutting solid surface wet. ive searched for threads in this forum
and seems it can be done but almost no one recommends it just want to know if anyone has seen it done and possible information.
thanks mike
Old 04-10-2006, 09:43 PM
ger21's Avatar
WHy would you want to cut it wet? It cuts just fine dry.
Old 04-10-2006, 09:46 PM
keeping the dust down and possibly cutting 2cm zodiaq
Old 04-10-2006, 10:00 PM
ger21's Avatar
A simple dust collector will keep the dust down. Can you cut Zodiaq with a router?
Old 04-10-2006, 10:38 PM
ViperTX is on a distinguished road
If you are really hung up on cutting it wet...then check out the tools at granitecitytool.com
Old 04-10-2006, 10:55 PM
is a new spindle needed to run water internally or just external
thx for help mike.
Old 04-23-2006, 01:07 PM
Stevie is on a distinguished road
I cut Corian with Paint thinner; it stops the dust; dries up easy and then just vac it off
[IMG] code is Off
