Results 1 to 8 of 8
Thread: Milling Durastone material using CNC
    Feb 2006
    MALAYSIA
    Could anyone help me to calculate the right RPM and Feed Rate for different size of endmill for durastone milling purpose?
    Apr 2003
    If you find the answer elsewhere, could you post it here? I need the information myself. Where can you get the durastone at a good price?
    Feb 2006
    MALAYSIA
    OK...
    Sorry, I got the material via my local vendors, which I don't know their sources.
    you should know also that there are many types of durastones available in the markets.
    Apr 2005
    bih
    there was someone on here making turrets for model ships out of that artificial stone thing, I think? he should be able to help. there are even pictures but I don't know the thread off the top of my head. it might be worth you while sifting through the threads in either diy routers or diy metalworking machines. good luck!
    Apr 2005
    bih
    ah here it is!
    The Evolution of a Home CNC Mill
    but it's "synthetic granite", does that count?
    Feb 2006
    MALAYSIA
    durastone
    em, I dont think that it is a synthetic granite material, but it is an epoxy glass material (if I am not mistaken)...
    Mar 2005
    What type of tooling are you using? We mill most natural stones and Cambria Quartz Surface in our shop using different types of tooling and feeds & speeds for each.
    Jan 2010
    Durastone is some of the nastiest material i have ever worked with , first of all i will suggest using a mask and long sleeve shirts and don't do anything to try to get the fiber glass out of your body... take a cold shower and sleep it off. after some years of working with it you will get used to it. lol. well i think about 150 SFM its the recommended. but i got my own theories. if using a 1/2 carbide endmill try 450rmp at a 25-35 ipm, but it all depends on how you are holding your material. 1/4 endmill 950rmp with 15ipm that should give you and idea. if you have any more questions be more specific in what you need to know and ill see if i can guide you in the right direction
  • Posting Permissions
