Results 1 to 2 of 2
Thread: Why use cutting fluid on limestone?
    Jun 2012
    Hi All,
    I saw the HackAday video of a guy shaping limestone with a screwdriver today. I also went and saw the YouTube video of CNC milling limestone. They were using a flood system with their mill.
    So, as a total newbie -- why flood limestone? It seems really soft. What would happen if you milled it without the liquid? What if you went shallow and slow, with cooling breaks for the tool -- would that work?
    Thanks!
    Apr 2004
    Oakland CA USA
    The flood coolant has several functions. It carries away the loose material dislodged by the cutting process, so it doesn't clog the cut or fill the air with dust that will settle everywhere. It also cools the tool, so it lasts longer, and keeps the heat from harming the stone.
    But you can cut it dry if you want - just do it outside, when nobody else is around...
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
  1. What cutting fluid do you use?
    By nateman_doo in forum Benchtop Machines
    Last Post: 02-10-2012, 02:37 PM
  2. Cutting Fluid Types
    By MecInd in forum General Metalwork Discussion
    Last Post: 03-18-2009, 02:41 PM
  3. Disposal of cutting fluid
    By naytep in forum General Business Practices and Pricing
    Last Post: 10-05-2007, 11:34 AM
  4. Cutting fluid
    By sleeper142 in forum Haas Mills
    Last Post: 07-29-2007, 09:05 AM
  5. Cutting fluid that doesn't smell?
    By sendkeys in forum General Metal Working Machines
    Last Post: 09-09-2004, 01:29 PM
