Results 1 to 3 of 3
Thread: Help CNC / Diamant tools
    Aug 2011
    Netherlands
    Hello
    I am new to the CNC world and Stone world, i work since 2008 at a stone company that does restauration and reconstruction in natural stone, mostly we use a 4Axis Bridge machine(GMM Blizz) for profile work and 90% of the work we use blades.
    Recently we have a bought a new machine (CMS Brembana G-Rex) I have started to use the machine about 2 weeks ago for a project we need to delivery, till now its going ok, the machine is not working 100% i am still running in to errors that need to be solve, but my biggest problem is tooling.
    Current i am using Nicolai tools, but feeds and speeds that they have for the tools are some times a little bit skechty.
    For this work mostly i am using segment wheels on a hard material (Irish Blue stone) with a spindle speed of 4400, 3mm removal , 500 Fixed feed and a width of cut 80mm and takes a lot of time to... to complete a piece the machine is about 25 / 35 hours.
    Maybe is some one out there that can give some advice/tips in tooling.
    Also if some one owns similar machine i am open to info.
    I have google a lot for CNC/Stone info but mostly i can find nothing worthy.
    Thanks in advance.
    Attached Thumbnails Attached Thumbnails Help CNC / Diamant tools-wheels.gif
    Mar 2010
    australia
    that sounds very very slow, any chance you can get a video of the machine doing the job? my email is t_kiwi@hotmail.com
    Anthony
    Dec 2011
    Belgium
    Hi Emptystr
    I programmed (with Alphacam) and used a Brembana G-Rex for two and a half years for restauration work, including scanning and implementing 3D sculpture stuff.
    14 Days ago I quited the job and went back to basics...Stonemason/Sculpture work by hand, at the base of a church in Brussels, in a makeshift shelter.
    Reason to leave: Not being payed as I schould have been...
    My former employer is still looking for a Alphacam Stone programmer as I was the only experienced AC Stone one in Belgium :-)
    About your tool question:
    Try to use a smaller with of cut with a higher speed --> the evacuation of sludge and cooling will be better.
    Check your spindle load amps with the CMS electrospindle software that came with the G-Rex...go for 20 Amps max.
    Go for galvanic wheels...I used the 85mm ones at speeds up to 1200mm/min with 3mm removal in Belgian BlueStone.
    I've once tested prototype wheel for Nicolaļ Diamant and got it up to 4000mm/min (3mm removal) in Massangis Jaune Claire...without any protest.
    Use 'Open Pocket' strategy's and lower in Z outside your workpiece...go for 6 to7 mm removal at 700mm/min, 30mm overlap with a 85mm wheel.
    (Een Baldakijn van bijna 1 cuub, beeldhouwwerk incluis, frees je in een weekend.)
    Succes!!!
  1. Mini-CNC machine tools and CNC machine tools-ray machine
    By aiven.xie in forum Product and Manufacturer Announcements
    Last Post: 09-24-2012, 02:53 AM
  2. Help on Emmegi Diamant Equipment Using Camplus
    By scott4tg in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 05-13-2011, 12:05 PM
  3. Bring your own tools or does your company supply tools?
    By ZipSnipe in forum CNCzone Club House
    Last Post: 02-04-2011, 08:06 PM
  4. KDN Tools
    By jleiwig in forum Benchtop Machines
    Last Post: 02-27-2005, 10:18 PM
  5. cme-tools.com?
    By HogDog in forum General Metalwork Discussion
    Last Post: 12-09-2004, 10:44 PM
