Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 10-08-2005, 09:45 AM
Chris D's Avatar
Chris D is on a distinguished road
PVC - Solvent and oil tolerance?
Does anyone know how well PVC holds up when exposed to solvents (mineral spirits etc) cutting oils, etc.? I want to use some PVC for machine guarding, but don't know it if will be attacked by the cutting oils and coolants etc.
TIA
Chris
Old 10-10-2005, 04:14 PM
One of Many is on a distinguished road
TIA
Chris
PVC, ABS and Styrenes are thermal formed type of plastics. Thermal set and engineered plastics like poly's, nylon and acetal types are less prone to chemical break down.
Organic solvents like ketones, chlor's and fuels will desolve thermal form types, but not engineered types. Oils are not much of a problem as long as they do not contain solvents. Miniral spirits should are not so bad. It may soften the surface and make it gummy. Test a piece for yourself. I usually put a drop of whatever solvent that may come in contact with the plastic, then rub my finger around in it to feel if it desolves the base materials. I have found out the hard way, that some contact cleaners cannot be used on switches with plastic housings.
Machine guarding is typically polycarbonate AKA Lexan. It is clear like plexiglass but not as brittle. Chlors and anarobics will craze the stuff and can cause fractures, but will not normally break it down. The nice thing about polycarbonate is it can be cold formed in a press brake to bend it.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 10-10-2005, 05:06 PM
anoel's Avatar
anoel is on a distinguished road
Acetone is really PVC's only real enemy... Oil's and Varsolve and stuff like that won't do much if anyhting to it.
Nathan
Old 10-10-2005, 06:19 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
Go here: http://www.coleparmer.com/techinfo/ChemComp.asp - probably the best on the net.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 10-11-2005, 08:39 AM
Chris D's Avatar
Thanks everyone!
Wow, some great information once again. Thanks!
Chris
[IMG] code is Off
