| Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here. |
I did some UHMW machining in the past and had great luck. I ordered a new sheet and I can't get any decent results. The material does not cut off cleanly and leaves connected strings all over the place. I used a new Onsrud bit made for this material. I dug up piece from my last experience and it machines fine. The old stuff is stiffer, glossier and whiter. The new stuff is milky and gummier. Neither is labeled well enough to determine much. Searching found several varieties. Does anyone know type machines the best? |
| The second sounds like polypropylene. UHMW is a great wear resistant and machinable plastic so you shouldn't have that problem. Found some data sheets that might help. Polypropylene, PolyPro Homo/ Co- Polymer Plastic Sheet - Rod | Industrial Plastic Supply, Inc. UHMW, Polystone, Lennite are Light and Super Wear Resistant | Industrial Plastic Supply, Inc. |
| Delrin vs UHMW | Jaladel | JGRO Router Table Design | 13 | 10-14-2011 12:35 PM |
| Milling UHMW | tanky321 | DIY-CNC Router Table Machines | 11 | 03-29-2008 07:56 PM |
| UHMW table | MBG | DIY-CNC Router Table Machines | 18 | 02-19-2008 03:54 AM |
| Where to buy UHMW | Breaker | DIY-CNC Router Table Machines | 10 | 02-04-2008 09:41 AM |
| UHMW for ACME Nut? | Thinwater | Linear and Rotary Motion | 10 | 01-17-2008 10:57 AM |
