Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 06-16-2011, 03:53 PM
gently is on a distinguished road
non-rusting cutting fluid for stone milling
I'm a complete newbie and next week take delivery of a hobby cnc mill Sieg kx3. Appreciate suggestions on a cutting fluid that I can use on limestone and marble that won't rust my mill but won't stain the stone.
Cheers,
Roger.
Old 06-23-2011, 12:23 PM
Nicken is on a distinguished road
cutting fluid
Dear Gently,
I am not aware of such a cutting fluid - may be the producer has to recommend if there is. But please bear in mind the following:
1. You will have to circulate the fluid in order to save it (save money as well).
2. After the stone being machined, there is a lot of waste from the stone getting into the fluid
3. The waste has different grain - it depends on the stone - limestone waste is very fine(like mess), white marble waste has a little bit bigger grain and granite grain has biggest grain. Then you will need a separation installation with deposit concrete tanks to filter and collect the waste - otherwise you could have a problems with the sewerage and local authorities.
4. At my work place I use water for coolant and we have a separation system with wastage collectors. Even after being filtered it the water contents some waste of previous machining. That is why you can not use all the same water or other coolant and you will have to renew from time to time. If you find a special liquid you will have to think about the expenses.
5. You can ask for coolant liquid in factories where they have lathes for mashining metals - they usually use a white liquid which do not rust.
6. I don`t think that liquid will colour the stone as it contents mainly grains , not paints. Of course you will have to be carefull when you machine painted granites or marbles such as Nero Zimbabwe, China Black, Verde Gwatemala. Rainforest Brown and Rainforest Green have natural paint - you have to be careful.
Best regards and luck. If you need any help, just write to me - nickabo@gmail.com
Old 06-23-2011, 01:15 PM
Thanks a lot. I'll try a few things and hopefully come up with a solution (no pun intended). I am just focussing on prototyping so the quantity of machining will be quite small.
Thanks again for your help.
Tags
cutting fluid, rust, stone
[IMG] code is Off
Cutting fluid for aluminum? Ben General Metal Working Machines 7 11-17-2011 09:03 AM
What cutting fluid are you guys using? douglasco CNC Swiss Screw Machines 3 07-13-2009 07:02 AM
Multan cutting fluid yuem Safety Zone 1 03-18-2009 12:57 PM
Disposal of cutting fluid naytep General Business Practices and Pricing 1 10-05-2007 10:34 AM
Cutting fluid sleeper142 Haas Mills 15 07-29-2007 08:05 AM
